Author Topic: Exhaust swap  (Read 1711 times)
Offline Wavey Dave
  • Bike: DL650 L6
Exhaust swap
« on: August 19, 2025, 13:26:38 »
Does the low level exhaust pipes from 2017 fit the high level 2016 I.e could you swap them over?
Offline nigel s
Re: Exhaust swap
« Reply #1 on: August 19, 2025, 13:48:03 »
Hmm...in theory yes, the main frames are the same as is the engine shape , if not the internals. The gen3 had 200 odd changes as I remember, so it may need a reflash ..maybe ... or at least a dyno run to check :shrug:,... It is just a matter of the hanger being different..hmmm..a little fabricating maybe  :shrug: , there would certainly be more clearance for panniers if that is your thinking. Interesting  :thumb:
But then the pannier mounts for a gen 3 won't work on a gen 2.....maybe go for a system that will allow retro fitting using a common pannier frame.
