Author Topic: Shoei Whisper Strip  (Read 2647 times)
Offline Oldie
Shoei Whisper Strip
« on: June 23, 2011, 16:30:45 »
Picked up a Shoei Whisper Strip this morning and just back from a 200 mile run with it attached. The decrease in wind noise is remarkable, even although the Qwest is a reasonably quiet lid to start with. Delivered from RaceVisors.co.uk within 24 hours for £21. Get one!
I can’t go back, I won’t go back
I’d love to go back but I mustn’t do that
Offline 2112
Re: Shoei Whisper Strip
« Reply #1 on: June 23, 2011, 17:31:25 »
Nice tip, my mate fitted on to his Shoei, made a big difference as you say. Not a bad price either.
Offline Oldie
« Reply #2 on: June 23, 2011, 17:37:41 »
I'm fairly sure that it's a universal fit, so should fit most helmets as long as you have a tiny gap between the shell and the liner. If you can get something like the blade of knife between them, then the whisper should fit in there too.
Offline 2112
« Reply #3 on: June 23, 2011, 20:12:50 »
I have seen an item that goes on the outside of the lid, kind of like a big elastic band, but it doesn't look too clever.
Offline Oldie
« Reply #4 on: June 23, 2011, 20:19:06 »
That could be the Windjammer. Looked at them before.
Offline badger 1050
« Reply #5 on: June 23, 2011, 21:00:42 »
I got on of the wind jammer type things stretched over the lower part of the helmet it was absolute crap used it twice and when going down the road it just rolled off
my missus tried it on her lid and got the same results
badger1050
Anonymous
« Reply #6 on: June 28, 2011, 19:04:52 »
I glued a bit of velcro into the gap in the foam at the front of my xr1000. Then got another bit of velcro and glued it to a 1 cm thick bit of foam nearly as wide as the gap. Stick the 2 together,  blocking up of that gap makes a huge difference to the wind noise.
Offline longman
« Reply #7 on: June 28, 2011, 23:23:41 »
wasabi I ve seen your helmet and your mods are great, simple and they work:)
Longman
Suzuki DL650 K5
Suzuki DR-Z400SM K7
