I think it is this this:
http://www.amazon.co.uk/Veho-VCC-003-Mu ... pd_cp_ce_0I have had it a couple of years now and they didn't have the model numbers at the time. It needs a micro SD card as well, but make sure you get class 6 or above so it can cope.
Its not the best quality images or sound by some way, but as a cheap and small camera it works okay and is manageable file size so you can shoot lots of footage and edit it down without worrying about file size too much.
You can get something off ebay which is very similar (identical in appearance) for much less, and I had one of those as well - I think it was about £12 but search under 'spy camera' rather than 'camcorders' and you can probably find them. The cheap one has similar quality images but they tend to have a permanent date stamp (which is fiddly to set and you can't get rid of it). Also the case of the cheaper ones is plastic rather than aluminium, and the controls are not as user friendly. Much cheaper though !
I also got the sports pack for mounting it:
http://www.amazon.co.uk/VEHO-GADGETS-EX ... 150&sr=8-2BUT, I have to say it was a lot cheaper then, and its pretty appalling value to be honest. I mounted the camera on the chin bar of the helmet, and used a strap from this kit, but a reckon any sort of velcro strap would do the same job for a lot less.
