Author Topic: Oil changes  (Read 1916 times)
Offline Mark65
  • Bike: Vstrom DL650 AM2
  • Location: Wigan (sadly the great pie shops are gone, RIP Pooles pies)
Oil changes
« on: August 28, 2025, 14:54:33 »
Hi,
Does everyone change there oil (fully synthetic) yearly even if they have only done 800 miles and the filter yearly as well (genuine Suzuki)
Thanks
Offline crump
Re: Oil changes
« Reply #1 on: August 28, 2025, 15:49:18 »
Personally I generally change my oil annually (or sooner dependant on miles) but at 800 miles I'd consider going another 12 months.
Offline Upt North
  • Bike: DL650 L7
Re: Oil changes
« Reply #2 on: August 28, 2025, 16:54:08 »
I'm with Crump. You've paid for premium oil which will not have deteriorated at all, why tip it down the drain? Which obviously you wouldn't.
Upt.
Offline Upt North
  • Bike: DL650 L7
Re: Oil changes
« Reply #3 on: August 28, 2025, 16:55:05 »
As an aside do they recommend full synthetic for the later STroms?
Offline Mark65
Re: Oil changes
« Reply #4 on: August 28, 2025, 17:28:57 »
No idea but it was was cheaper than Motul 5100 that I  used to use.
All my mileage this year has been motorway with a little a roads at each end.
Offline Upt North
  • Bike: DL650 L7
Re: Oil changes
« Reply #5 on: August 28, 2025, 17:55:15 »
Even more reason not to change it, unless you were attempting a land speed record.
My oil was changed on returning from Italy October last year, that was a 4500 mile two up jolly jaunt. I've done very little this year, I'm guessing,  but probably around 1500 miles on semi synthetic. It won't be changed before next spring at the earliest, it still looks as clean as new.
I really don't prescribe to the cheap insurance rhetoric. Firstly it isn't cheap and secondly if you do prescribe to this mantra then wouldn't you change it every month........just in case?
Edit.....when I dropped the oil from the trip that also appeared very clear and clean, that and this fill are 5100.
