I had one....or a CJ360 anyway , the same colour...
Late 80s, paid £250ish for it sold for same .
Gruntier low down than the 400 Superdreams I had later , though worse handling . Brakes are woeful when wet, but weren't they all back then.
Rear wheel spokes coming loose ( same as a Benly I had ) and setting the points were the problems ...as I recall..a while ago now.
The points were fiddly, I set with a test lamp , then tightened the adjuster plate bolt and it moves... have to set a bit out then when tightened brings them in to the right spot..
David Silver...as you know
