'Ello folks!
For your general all purpose lubrication needs, what are your go to's?
Not just for the bike but also things like door and window hinges, squeaky fridge doors, Locks etc...your general household issues?
I've always used WD40, Just because I like it, it also seems to work fine and I don't have any issues caused by it (that I know of). I'm interested in what the consensus is though.
I'm considering going for 3-in-1 (aerosol) or GT85 as I keep seeing people say that WD40 isn't a lubricant, its a penetrant. (but in fairness, it says it lubricates, so...
If its something that specifically needs lube, I like to use 3-in-1 oil, but with it not being in an aerosol can be a bit trickier to get to the right place sometimes hence me considering the aerosol version.
In all honesty though - WD40, GT85 and 3-in1 (aerosol) seem to be the same thing...
I'm sure there is some chemical differences and some fancy pants reason they're not the same. but......
Interested in your thoughts gentlemen.
P.s. I'm obviously not talking about anything that needs grease or specialist lube etc.
P.P.S. I'm well aware using WD40 in locks is going to trigger some people, but ill be frigged if I'm finding some dry graphite crap to carefully get into a lock cylinder.
