Author Topic: 800re screen recommendation  (Read 5114 times)
Offline Pope
  • Bike: DL1050XT M0
« on: July 24, 2025, 11:40:06 »
Hi all. What screen would you recommend on the RE please. I am 5ft 8 , the standard screen doesn't work for me and neither has an MRA screen! Thanks
Re: 800re screen recommendation
« Reply #1 on: July 24, 2025, 13:26:46 »
Have you tried one of these on the OEM or the MRA?
https://www.ebay.co.uk/itm/376206542364
Works great for me & just as good, maybe better than the Givi Airflow I had on the 650.  :)
Plus, it's cheap enough to try before you spend a lot on anything else.
I initially had it on the 'touring screen', which is a little higher than the standard, I tried it on the standard & it's even better.
Photo to show how I have it fitted. It didn't take much to sort it, but may need a few adjustments to get it right.
Offline Pope
  • Bike: DL1050XT M0
« Reply #2 on: July 24, 2025, 13:45:56 »
Thanks Mick,
I have just ordered one....for 12 quid...
Regards Paul
« Reply #3 on: July 24, 2025, 13:58:44 »
Mine didn't come with instructions but it does fit together easily enough, was you get the idea.  :whistle:
I've marked on this photo where I've wrapped a bit of tape around the fastening because after a few months I noticed it was coming loose.
It's only £12 & I didn't expect that much from it, but that does seem to be a weak point.  :thumb:
Offline Sir Trev
« Reply #4 on: July 26, 2025, 15:41:52 »
I angled the stock screen on my RE with 10mm spacers on the bottom mounting points (and longer bolts). Having the top of the screen a bit closer to me reduced the buffeting a fair bit, although 20mm may well be even better. Very cheap mod to try.
We are the Goon Squad and we're coming to town - BEEP BEEP!
Offline Pope
  • Bike: DL1050XT M0
« Reply #5 on: July 27, 2025, 07:57:15 »
Thanks Trev. I will try that as well. I have also been thinking that at least part of the problem is the ( non) angle of the screen. Where did you get the spacers and bolts?
Offline Pope
  • Bike: DL1050XT M0
« Reply #6 on: July 27, 2025, 22:38:38 »
Has anyone tried the givi vario airflow( I think the names is)
« Reply #7 on: July 28, 2025, 09:38:10 »
A member on Stromtrooper made a 3-D printed spacer for his DL800 DE screen that he now sells, https://www.stromtrooper.com/threads/any-further-opinions-on-dl800-Windscreen -windscreen-options.445172/page-4?post_id=5763146#post-5763146
If you have access to a 3-D printer, you could either try to simulate a similar spacer or else perhaps place an order with that StromTooper member.
