Author Topic: Heathrow power outage  (Read 2045 times)
Offline 2112
« on: July 02, 2025, 11:33:46 »
The interim report into the Heathrow power outage back in March this year has been released today. It makes very uncomfortable reading for a number of parties, not least National Grid & Heathrow Airport itself. Basically, an issue was found with a transformer bushing (a hairline crack, quite common) back in 2018 but nothing was done about it. This allowed the ingress of moisture into the transformer oil, degrading it's ability to insulate over the years. It was due for a routine maintenance in 2022 (when it should have been fixed) but this also got cancelled. It went 'bang' quite spectacularly in March 2025... This is endemic in the electricity industry and goes directly back to privatisation in 1990. This is not a rant about the politics of the situation, but a simple statement of facts, this event highlights the lack of investment in infrastructure. This is common across the whole industry and not just limited to National Grid. Having worked in the industry for 43 years I have a lot more insight than most. 100+ year old cables? Yup, 80+ year old poles? Yup.
The lack of investment is genuinely worrying and causes numerous power outages across the country with the enevitable vast financial losses every year. Under the current Ofgem regulations National Grid and the DNO's have to spend 'X' amount (it varies from each operator) on replacement of assets every year. This is not targeted asset replacement, instead it depends on each operator to decide what they spend the money on. This tends to lead to the 'easy' reinforcement scheme's going ahead and the more challenging ones being put on the back burner, rather like what happened at Heathrow. What it needs is for Ofgem to set a lifespan for assets and then oblige the operators to keep to that lifespan - and fine them if they don't keep to schedule. It's not rocket science...
Offline MisterDavey
  • Bike: DL1050 M3
Re: Heathrow power outage
« Reply #1 on: July 02, 2025, 11:49:45 »
Everyone is greedy, and there aren't enough pieces of pie to go around to satisfy the greed, so the structure of business falls apart because nobody will sacrifice their piece of pie.
Remember, you can cheat death a thousand times, but death only has to win once.
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4.
« Reply #2 on: July 02, 2025, 11:51:20 »
The world has become a very greedy place and the rich want all of the money, spending none of it where it's needed. The end of the world is coming and it will all be over so don't worry too much.  :roll: :thumb:
Edit: I must have been typing at the same time as MisterDavey and we have both said the same thing so it must be true.  :smirk:
Offline Upt North
  • Bike: DL650 L7
« Reply #3 on: July 02, 2025, 12:49:51 »
It isn't just the leccy either.
The roads are literally falling apart and nowt's being done about it.
Look at the flyover in Gateshead, literally crumbling to dust on a busy commuter route. The answer......knock it down and put a flower bed in! If they can afford the daff bulbs of course......where does all this f'in tax go to?
Pffffffftttttt.
Offline FR22
  • Bike: V Strom 800DE
« Reply #4 on: July 02, 2025, 13:56:26 »
Definition of current society....
Pffffffftttttt.
Around here, the roads are seriously out of control due to lorries and a massive industry in country roads. Dangerous in a bike at night, unless you know where the potholes are...
Answer from the council? maybe 2027...
