Hmm, not had one , but you could be right about voltage drop Brockett.
Have you had a look at the status light on the TB when it shuts off the Sat Nav to confirm ?
Also, do the 2 bikes fitted with the TB get used less often, how are their batteries? slightly weak ?
Disconnecting the TB from battery for 5 secs will act as a reset for it , may be worth a try.
Also it can be connected by the white wire to a switched source and then used as a normal relay box, an option , but that kind of defeats the purpose of easy install
