Author Topic: Kappa ks310 lights - bulbs?  (Read 3348 times)
Offline ScaredyCat
  • Bike: DL1050 M3
« on: March 10, 2025, 11:15:20 »
Hi,
anyone know what bulbs are needed for the Kappa KS310 lights?
I think they're the same lights sold as the Givi KS310 - at least they look the same.
Offline purplebikeunicorn
  • Bike: DL650A L7
Re: Kappa ks310 lights - bulbs?
« Reply #1 on: March 13, 2025, 03:02:44 »
Given that Givi and Kappa are the same company then they are almost certainly the same. The only difference normally between their stuff is that Kappa stuff may be a bit more "rough and ready" than the Givi... at least in my experience!
Offline Upt North
  • Bike: DL650 L7
« Reply #2 on: March 13, 2025, 09:37:20 »
MPN   KS310
Tipo di lampada   H3
Brand   KAPPA
Marca   KAPPA
EAN   8029871097799.
Or so it says.....
Good luck.
Upt.
Offline ScaredyCat
  • Bike: DL1050 M3
« Reply #4 on: March 13, 2025, 10:11:06 »
Ouch!
Offline Upt North
  • Bike: DL650 L7
« Reply #5 on: March 13, 2025, 10:46:40 »
If they are H3 then they should be available just about anywhere.
Take em out, check the ratings and voila.
Upt.
« Reply #6 on: March 13, 2025, 11:47:44 »
Ouch indeed. Which, along with lower current draw, os why many use led spot / fog / auxiliary lamps.
« Reply #7 on: March 13, 2025, 11:51:16 »
https://www.ebay.co.uk/itm/192734717983?_skw=H3+bulb&itmmeta=01JP7N77TMZENDJ9GNKHFBV1PE&hash=item
I searched for & tried 3 different LED options for mine but never found any that would fit well & put out the 'brighter' light through the centre of the glass/lens.
« Reply #8 on: March 13, 2025, 12:14:38 »
Just had a look in the garage & found some. There's 4, the boxes are a bit battered but the bulbs are OK. The one on the right isn't the Xenon Effect type, the other 3 are.
If you want them, no charge, PM your address & I'll get them in the post to you.
Offline ScaredyCat
  • Bike: DL1050 M3
« Reply #9 on: March 14, 2025, 09:35:41 »
 :thumb:
Many thanks for your generosity, but I've ordered a couple online - it'd be wrong to take yours now.
Much appreciated though.
« Reply #10 on: March 14, 2025, 10:36:21 »
No problem.  :thumb:
