Author Topic: Safe to ride after removing this nail?  (Read 3120 times)
Offline bonne
  • Bike: DL1050 M0
« on: August 20, 2021, 10:17:13 »
I will have to check if the tyre lose pressure... if not, is it then safe to drive on?
Re: Safe to ride after removing this nail?
« Reply #1 on: August 20, 2021, 10:28:57 »
If your tyre isn't leaking air , yes .
« Reply #2 on: August 21, 2021, 07:49:46 »
I suspect that the nail may have gone though the inner belting / weave and will cause a slow leak. Test with tyre once inflated to the correct pressure, sponge on a soapy water mix and observe if any bubbles. If any sign of a leak, you may require a sticky string / rope  or similar repair job. Have a look at the video in https://www.v-strom.co.uk/smf/index.php?topic=39375.0 for a suitable solution.
Offline bonne
  • Bike: DL1050 M0
« Reply #3 on: August 21, 2021, 08:52:09 »
I actually have a repair set along with me that I can use in emergency.
But I rode something like 300 km on it now without any visible loss of pressure. I will measure correct later.
« Reply #4 on: August 21, 2021, 13:14:05 »
A reminder of "sod's law".....
If a thing can go wrong,  it will go wrong and at the worst possible moment.
If it was my tyre I'd have it professionally 'plugged'.
Offline Mr Nick
« Reply #5 on: August 21, 2021, 14:14:00 »
If it has only made it into the rubber then you're more likely to cause an issue by having someone drill into the carcass to plug a hole that isn't there. If this was my tyre, I'd bubble test it and repeat that after a ride or two. If there was no leakage then I'd leave it as is but keep an eye on it.
Orange Bikes Matter!
Offline bonne
  • Bike: DL1050 M0
« Reply #6 on: August 21, 2021, 20:38:58 »
yeah, I follow you, Mr Nick. Pressure was slightly lower than yesterday, but I checked at another gas station, so I think it is because of difference calibrated equipment. I will soon change the tyre anyway
Offline bonne
  • Bike: DL1050 M0
« Reply #7 on: August 23, 2021, 09:43:42 »
Tyres changed... Just in case
Offline Oop North John
« Reply #8 on: August 23, 2021, 10:58:03 »
I always try to use the same pressure gauge, then at least the results are consistent. Checking it against another which is know to be accurate really helps as well!
Offline bonne
  • Bike: DL1050 M0
« Reply #9 on: August 23, 2021, 11:30:43 »
Yeah ... but I was 200 KMs away from the first gauge (;
« Reply #10 on: August 23, 2021, 16:15:07 »
Too late now, but next time, take one with you, they're not that big and will take up little room.  :)
