Author Topic: headlight adjustment/bulb replacement  (Read 1742 times)
Offline theoldun
  • Bike: DL650 L9 Red
« on: September 08, 2020, 16:57:49 »
In the past on other bikes this was a 5 minute job .But I have read the handbook and it would be easy if I could get to the adjusting screws and bulb . The plastic around the instruments needs to come off to get access, but how? Someone must have done this and it surely can't be too difficult , I dread to think of trying to replace a bulb on a trip which I have done twice in the past on other bikes.  My bike is a 2019 650 vstrom by the way. Any advice welcome as I surely have not got to take it to a dealer just for headlight adjustment
Offline MrNorbH
Re: headlight adjustment/bulb replacement
« Reply #1 on: September 08, 2020, 22:36:38 »
The White goes faster..everyone knows.
Offline theoldun
« Reply #2 on: September 09, 2020, 11:08:10 »
Thanks for reply. Very fiddly but managed with small 10mm spanner.  Don’t think I would be able to replace bulb that way but let’s hope that’s some way off
Offline theoldun
« Reply #3 on: September 09, 2020, 21:17:40 »
Tried this evening after dark.  Still far too high. I turned adjuster about 4 flats anti-clockwise and main beam still up in the trees so try again tomorrow with maybe another 10 flats and see how that goes . Update tomorrow evening
Offline theoldun
« Reply #4 on: September 13, 2020, 07:25:51 »
Got the lights adjusted to the correct angle by trial and error so main beam is now on the road and not up in the trees. Very fiddly with a small 10 mm spanner but no bodywork removed. By the way it is definitely clockwise to lower not anti-clockwise as I had read on this forum.
Offline brettchallenger
  • Bike: DL650 L8, Jawa 350
« Reply #5 on: September 13, 2020, 17:36:50 »
It is much easier to do with a long reach screwdriver.  It would be better though if Suzuki managed to get the lights focused at the factory.  Honda seem to be able to manage this.
« Reply #6 on: September 13, 2020, 21:16:57 »
       The pre-delivery check at the dealers should sort this out.
