I have owned a Motolug for probably 5 years now. I bought it used for £400 and would probably get close to that if I sold it now. It has paid for itself several times over compared to paying to have a bike delivered by a courier because I tend to change bikes regularly!
It really is a huge bonus not having to tow an empty trailer. I also use it when I work away for a few months every year and trailer a bike with me. It has taken all bikes, large and small, from a Honda C100 to an R1100GS.
I am a fairly fit 58 year old and I am able assemble and carry the parts OK. Tips if you buy one..........get a pair of leather workmans gloves for carrying the bits, particularly the main piece as the edges of the metal can hurt a bit.............fix carrabiners with threaded locks to each of the four strap fixing points by the wheels because the existing holes have sharp edges and tend to cut into ratchet straps...........never, and I mean never, rely on straps with hooks to fix the bike. If the suspension compresses over a bump they can undo (not just relevant to Motolug) ...........when fixing bike, put a strap through the front wheel and around the wheel chock so the bike can’t move backwards...........get hold of a bit of ply or melamine about 400 or 500mm wide the same length as the main part when folded. This makes loading in and out of the car MUCH easier as it slides in easily on the wood as opposed to digging into the carpet as you struggle to get it in. To load, put the wood on the step of the boot and slide the part onto it. You can then lift the wood up and slide it into the boot.............make sure all the bits are well wedged into your boot so they can’t roll as you corner. I use my wifes old gym mat to protect the boot side plastics.
