Author Topic: BigPie Aux Fusebox MK2  (Read 24228 times)
Offline Strominacup
  • Bike: DL650XT M2
Re: BigPie Aux Fusebox MK2
« Reply #60 on: December 20, 2023, 17:06:22 »
Or actually, just thinking, would I just attach that wire to a piggyback fuse?
Offline vstroman
« Reply #61 on: December 22, 2023, 13:20:15 »
I wonder if the original version will fit on the vtsrom 800re? Haven't had a test ride yet but it looks like a great bike and a good step up in power from the 650.
Offline Strominacup
  • Bike: DL650XT M2
« Reply #62 on: January 02, 2024, 21:47:34 »
I suppose it would as long as there's a switched live connection which is compatible?
Offline purplebikeunicorn
  • Bike: DL650A L7
« Reply #63 on: January 02, 2024, 23:14:30 »
Strominacup - couple of reasons your camera likely has a switched live plus permanent live, one is so that it can  do a "parking mode" recording, or more likely (especially if the camera unit does not have an internal battery), so that it can gracefully shut down and save the last bit of video to the SD card without corrupting it.
If unsure, I would wire it as per the manual, red and black to the battery, and use Bigpie's fuse box to trigger the ACC wire.
The advantage of this is that the ACC wire is not likely to draw any significant current, so you could put something else in the same hole too.
