Author Topic: BigPie Aux Fusebox MK2  (Read 24227 times)
Offline sidbig
  • Bike: DL1000 L8
Re: BigPie Aux Fusebox MK2
« Reply #20 on: March 25, 2019, 19:53:54 »
Nice one. Any photos of the install?
where the cable is on the v 1000 2018 and where I put the box at side of the battery
Offline Fritz
  • Bike: DL650 K9
« Reply #21 on: April 11, 2019, 13:23:34 »
Fitting to a 09 Weestrom - the wire - orange and grey (or white) and black - in the shadow (under coolant tank, under petrol tank)
Offline Fritz
  • Bike: DL650 K9
« Reply #22 on: April 11, 2019, 13:26:19 »
close up of connector - flipping hard to get to & mine has a cable tie just besides, but easy to disconnect once past the gynecological constrictions  :)
Offline Fritz
  • Bike: DL650 K9
« Reply #23 on: April 11, 2019, 13:31:49 »
Disconnect (fairly easy - look at a connector you can get to easily to see where clip is before ferreting about :smirk: - clip in aux each end and move back to a safe point in void and move on to where you want to put the box etc. Good bit of kit and will save considerable faff and any future worries and access problems for add-ons.  :clap:
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #24 on: April 11, 2019, 13:35:53 »
Cheers for the detailed photos Fritz
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #25 on: April 18, 2019, 12:15:27 »
I've had a question about water getting in it. Here's a demo
Offline hotbulb
  • Bike: DL650 L4
« Reply #26 on: April 18, 2019, 12:29:35 »
Are you now supplying to submariners too?
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #27 on: April 18, 2019, 12:39:04 »
I've had someone buy one and have concerns about rain and crossing streams, though if an submariners need a 12v relay fusebox, I'm your man.
Offline bronto
  • Bike: DL650 XT L7
« Reply #28 on: April 18, 2019, 12:50:36 »
Can anyone tell me what fuses I need? Obviously not very electrically minded here.
The live red has a spot for a fuse and also what fuse should I use in the box? Planning to put my heated grips through the box?
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #29 on: April 18, 2019, 13:57:42 »
Heated grips either a 2amp or a 3amp. Just stick at 15 or 20 amp in the main fuse holder.
Offline Andyruss
  • Bike: DL650 K8
« Reply #30 on: April 18, 2019, 19:47:18 »
Just got my fuse box from BigPie today. Looks like a good piece of kit and will make things easy for an electricity challenged person like myself!! Will get a few pics of the install once I get it fitted
« Reply #31 on: April 18, 2019, 20:16:07 »
Got mine yesterday. Looks good & I'm sure it'll work just as well.  :thumb:
Thanks.
Offline pichulec
  • Bike: KTM 1290 SAS
« Reply #32 on: April 19, 2019, 19:17:26 »
I like the design but original is just smaller, I will keep it, it is doing great job :)
« Reply #33 on: April 19, 2019, 21:09:12 »
If you take the bullet connectors out of the equation is the mk1 still smaller? Mk2 just terminates in the unit itself - very neat and easier for the end user.
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #34 on: April 21, 2019, 11:44:15 »
I'll take some side by side photos later, the mk1 on my bike will be replaced by the mk2 that's been under water.
Offline Dav4008
  • Bike: 2010 Year DL650X V-Strom in Black
« Reply #35 on: April 26, 2019, 10:26:01 »
Hi Gents
Thanks to Bigpie I have now fitted my auxiliary power fusebox and run the heated grips and USB connector through it, Lights to be added when I finally decide between 55w Halogen or 35w LED's for added visibility on rainy mornings! Pic attached! Very easy install, Thanks Bigpie.
Offline P248
  • Bike: BMW R1250GS (it replaced my DL1000 GT K7), KTM RC8, Suzuki GS1000EC (one owner from new in 1979, me!)
« Reply #36 on: July 25, 2019, 14:03:50 »
Hello BigPie,
Do the dimensions for the Mk2 version given in your post include the fitted fuses and relay?
Offline Stonec0ld
  • I was Paul_Nicholson
  • Bike: DL650A L5
« Reply #37 on: May 12, 2020, 11:09:36 »
Got mine today thanks! Just need to figure out where it goes...
Offline bigpie
  • Site Donator
  • Bike: DL650
Offline Stonec0ld
  • Bike: DL650A L5
« Reply #39 on: May 12, 2020, 13:38:55 »
Instructions pah! Who needs instructions!
Me obviously as I didn't think to put a fuse in...  :shy:
