Author Topic: Scottoiler Fitting  (Read 3902 times)
Offline chrism
  • Bike: 2018 DL650XT
Scottoiler Fitting
« on: October 02, 2018, 11:03:04 »
Hi,
New to the forums, just picked up my new 2017 model DL650XT.  I have ordered a Scottoiler for it, for the Vacuum connection, does anyone know if this can be connected without lifting the tank?
thanks
Re: Scottoiler Fitting
« Reply #1 on: October 02, 2018, 12:34:39 »
There are two vacuum take off points on the rear throttle body,use one of those.They are a swine to get to.You have been warned! Not sure about the tank removal,on the earlier bikes just a couple of side covers on the RH side have to come off.
    (BTW have you got any plasters handy.) :)
Offline Griff2
  • Bike: DL1000 L6
« Reply #2 on: October 02, 2018, 16:03:33 »
Cancel the order and get a Tutoro. Works better and no vacuum take offs.
Offline nwil
  • Bike: 650 v-strom
« Reply #3 on: October 02, 2018, 19:05:23 »
Fitted one a few months ago.
Can gain access from the side, a little fiddly but no problem.
No need to remove tank.
From memory the scottoiler site has instructions on-line for the 17+ model.
Offline harmony
  • Bike: DL650, VFR1200X
« Reply #4 on: October 02, 2018, 19:48:06 »
Just received mine for the glee.  Will probably fit in the next couple of weeks.
Offline chrism
« Reply #5 on: October 02, 2018, 20:15:00 »
Hi,
Thanks everyone, should arrive tomorrow so all going well it will be fitted tomorrow.
Will let you know how I get on and any gotcha's I find
Thanks
Offline hotbulb
  • Bike: DL650 L4
« Reply #6 on: October 02, 2018, 21:13:16 »
The Scottoiler site has instructions for specific models,and I found these quite helpful when fitting one to my Glee (2014), and I managed without lifting the tank etc. Fiddly, but possible with a bit of patience.
 However, they don't, so far, have anything for the latest, beaky, single-headlight 650 model. It may well be the same as the Glee, but if it's "Euro 4" compliant, the setup may be different .. Scottoiler give generic instruction for such bikes.
