Oil/Lubrication
Oil for a Scott oiler? Where from?
Topic: Oil for a Scott oiler? Where from? (Read 7578 times)
Parademic
June 27, 2015, 20:04:16 »
Where's decent and well priced to buy oil for a Scott oiler (or similar)? The official oil refills are quite pricey, and I'm guessing there are some cheaper alternatives out there that do just a good job of lubing my chain...
Cheers,
Gareth
Ali p.
Bike: DL650 XT AM1
Re: Oil for a Scott oiler? Where from?
June 27, 2015, 20:14:27 »
Use chain saw oil mate just as good lots cheaper
mr_diver
Bike: 'onda Varadero XL1000v9, 'onda CX500ec '83, GSX14 K6, DL650 K6 (Blue) R.I.P,
June 27, 2015, 21:37:36 »
used engine oil
Twiggy
Bike: KLV1000
June 27, 2015, 21:40:10 »
EP80/90 is very similar stuff a day much cheaper.
Neil
mr_diver
June 27, 2015, 21:45:31 »
what can possibly be cheaper than used Halford's own brand oil that's done 4,000 miles in your engine already?
seriously though, I've used all sorts of oils in the scottoiler, chainsaw oil didn't fling off much, but did get allot of crud stuck to the chain, that was a pita to clean off.
MartinW
Administrator
Bike: DL650 K4 Blue
Reply #5 on:
June 27, 2015, 21:51:50 »
PD Oilers recommend
THIS STUFF
which may or may not be cheaper than Scottoiler Oil (I don't know) but is more expensive than old engine oil.
But it is designed for the job too.
I bought a 500ml one for mine and it should last me forever.
Yoyo
Reply #6 on:
June 28, 2015, 08:29:55 »
Scott often have BOGOF deals online which makes the stuff affordable, not as cheap as used engine oil though!
mr_diver
Reply #7 on:
June 28, 2015, 08:38:26 »
Parademic
Reply #8 on:
June 29, 2015, 21:33:41 »
great... I'll go drain my neighbours car tonight once he's gone to bed and see how his oil does in my oiler... Thank u all...
Hondaman
Bike: 650 L3
Reply #9 on:
June 29, 2015, 21:50:27 »
I found ep90 too thick to flow reliably in colder weather and tend to stick with old engine oil but it can sludge up & bung the feed pipe, maybe my home made reservoir is partly to blame for that though.
I refuse to pay more for chain oil than engine oil!
mr_diver
Reply #10 on:
June 30, 2015, 07:27:29 »
Yes I always use the old bike oil not the gunk that drains out of the mrs diesel car.
I have drained a flushed the scotoiler tank and giving the chainsaw oil a go as I still have 300ml there as a test as the chain has done 14k and I will be changing it before the end of summer.
Used engine oil only needed a little increase/decrease on the dial when we went from colder months to warmer months and vis versa, chain oil being thicker needed quite a bit more adjustment.
Oop North John
Bike: DL650 M0, YB100 - 1990
Reply #11 on:
June 30, 2015, 08:01:48 »
Set up correctly the oilers hardly use any oil, so I'm happy to pay the small premium for nice clean oil going into my oilers, and which is less likely to fling. But I don't do tens of thousands of miles a year on my bikes.
Joe Rocket
Bike: DL650A L5, Kawasaki GPX750R
Reply #12 on:
July 24, 2015, 21:51:07 »
Quote from: "Oop North John"
Set up correctly the oilers hardly use any oil.
Quite right! If you only have to lubricate your chain (suggested intervals) every 500 miles then that can only mean a few drops now and again. I've put a manual Tutoro feed on my bike and it only needs the slightest feed for a brief 15-20 minute feed which is about a teaspoonful (or two) every 200 miles. This is not calculated but provides a moist chain without fling on the rear tyre. Oil is CLEAN NEW cheap chainsaw variety.
I've cleaned the chain once in about 4k Miles, another clean before 6k I think.
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
Reply #13 on:
August 26, 2015, 18:41:58 »
+1 for PTLube, keeps chains in great shape, doesn't fling much, smells nice (for what it's worth) and, most importantly, is easy to clean off the bike and the chain.
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
Oil/Lubrication
