Author Topic: Ratmobile Mods  (Read 15697 times)
Ratmobile Mods
« on: February 26, 2015, 18:27:14 »
I thought I'd give this section an airing  :)
This is the Ratmobile (2) and here are some of the mods I have done (much the same as Ratmobile 1).
Loading Ramps (one for the bike and one to walk up)
Fuel Cans (in some great little holders)
Auxiliary Battery Under the Passenger Seat, this is charged from the Alternator and also Mains.
12v - 240v Inverter - Crap picture but this gives me 240v from the Aux. Battery
12V Fusebox - Speaks for itself really, also a Voltage display so I know when the Aux. Battery is low.
12V Outlets - Fed from the Aux. Battery
Panel Heater - Being cold is for weirdos and Eskimos'
Lights - No Disco Ball this time  :shy:
Comms -
Rat -  :)
 :vanping:
Re: Ratmobile Mods
« Reply #1 on: February 26, 2015, 18:43:31 »
How much current does the radiator drag? With a radiator keeping things cosy this vanping malarkey may just have something going for it! Don't tell anyone else I said so though, eh...
Re: Ratmobile Mods
« Reply #2 on: February 26, 2015, 18:57:46 »
The Rad is only 850 watts so will draw approx 3.5A @ 240v. I've yet to test the efficiency of the Inverter but I have also wired an Electric Hook up point so I can connect the Van to Campsite power sockets  :old:
Re: Ratmobile Mods
« Reply #3 on: February 26, 2015, 19:58:18 »
No toilet facility in this Mk2 van then?
Re: Ratmobile Mods
« Reply #4 on: February 26, 2015, 20:10:42 »
The loo is in the Man Cave and will be slung in the Van ready for any Vanping   :)
 :vanping:
Re: Ratmobile Mods
« Reply #5 on: February 26, 2015, 20:11:31 »
jeeezzz, this Dogging thing seems expensive  :crazy:
Offline Robotstar5
Re: Ratmobile Mods
« Reply #6 on: February 26, 2015, 20:18:58 »
What about a solar panel to charge the aux battery if you're parked up away from a hookup.
Offline ziggy
Re: Ratmobile Mods
« Reply #7 on: February 26, 2015, 20:20:51 »
Andy that will drag 85 amps per hour off your battery. Hope it's a big one.
http://www.redarc.com.au/handy-hints/-/ ... rrent_draw
Re: Ratmobile Mods
« Reply #8 on: February 26, 2015, 20:50:54 »
Yep, it would last just over an hour. However, I don't intend to run the Panel Heater from the battery for extended periods, it has a timer on it and 10 minutes of heat in the space it's in is plenty.
Offline Ptarmigan
  • Bike: CRF1000 Africa Twin
Re: Ratmobile Mods
« Reply #9 on: February 26, 2015, 21:43:25 »
Quote from: "Fat Rat"
 :vanping:
The bog roll above the ramps is going to be a bit of a stretch from seated.  :shrug:
And I'd recommend placing it in carefully rather than slinging it, those things aren't exactly watertight!  :-x
 lol
Re: Ratmobile Mods
« Reply #10 on: February 26, 2015, 21:47:52 »
Bog roll??
I am at one with nature I'll have you know. Bear Grills next series is all about Vanping.
It's the way forward  :)
Offline Jeff999
Re: Ratmobile Mods
« Reply #11 on: February 26, 2015, 22:26:40 »
What comms setup do you have Andy? I'm 3 weeks into the Foundation course so will be wanting mobile comms once I hopefully pass.....
Re: Ratmobile Mods
« Reply #12 on: February 26, 2015, 22:33:24 »
It's a Yaesu FT-7900 (UHF & VHF) Jeff, they cover the PMR band too with a slight modification.
It's impossible to fail the foundation course  :)
Offline kirky1298
Re: Ratmobile Mods
« Reply #13 on: February 27, 2015, 11:46:37 »
Are you insulating the back and lining it with carpet Andy ?
Otherwise you'll be soaking with condensation  :thumb:
Re: Ratmobile Mods
« Reply #14 on: February 27, 2015, 12:09:28 »
Kirky,
I'll keep an eye on that  :thumb:
Offline Robotstar5
Re: Ratmobile Mods
« Reply #15 on: February 27, 2015, 16:08:18 »
Nice bit of kit, I've used an earlier model, FT-8800R on RAYNET events.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Ratmobile Mods
« Reply #16 on: February 27, 2015, 16:14:29 »
Damn you, you've made my mind start ticking again and wanting a van.
http://www.convertyourvan.co.uk/racevanconversions.html Looks expensive but well thought out.
Re: Ratmobile Mods
« Reply #17 on: February 27, 2015, 17:32:59 »
t's the way forward   :smirk:
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Ratmobile Mods
« Reply #18 on: February 27, 2015, 18:43:26 »
I'm loathed to admit it but it does make sense. How do insurers react when you mention the electrical mods inc space heater?
Any plans to attach an awning for extra space or extensions on hydraulic ram?
Re: Ratmobile Mods
« Reply #19 on: February 27, 2015, 18:47:35 »
I haven't mentioned the mods to the insurer, I suppose that would only be a problem if it burst into flames  :)
I have a Gazebo and no plans for hydraulic doodah's  :grin:
