Author Topic: Activ8  (Read 8558 times)
Offline Chris D'Pirate
  • Username: Chris DPirate
  • Chemist, Physicist, Pirate
  • Bike: K9 V-Strom 650
Activ8
« on: August 15, 2013, 17:11:00 »
Universal friction reducer - has anyone else here used it in their Strom?
I'm about to add it in prior to my European trip.
Offline iansoady
Re: Activ8
« Reply #1 on: August 15, 2013, 17:15:46 »
I tend to stay away from additives. I'm not convinced by their "user testimonials" and believe that decent quality oil should be quite enough.
Ian.
2005 DL650
1931 Sunbeam Model 10
Re: Activ8
« Reply #2 on: August 15, 2013, 17:19:53 »
as bikes with wet clutches WILL get issues with clutch slip when using oil rated as "energy conserving" or "reduced friction" I'd recommend you don't use this unless you want to immediately be replacing your clutch discs.
It would be bike in an engine with a separate dry clutch like a the 1150 or 1200 BMW's but not in the V-Strom!
Offline ziggy
Re: Activ8
« Reply #3 on: August 15, 2013, 18:11:45 »
From past experience in Industry there is no doubt that some oil additives work, but do not use when you have a wet clutch as already been stated.
Re: Activ8
« Reply #4 on: August 15, 2013, 18:15:56 »
it does state on their website it is suitable with wet clutches- the only way to truly find out is to use it, but new clutch plates cost £45min for crap ones and if you're not a mechanically minded person your looking at a fair bit more for a dealer to do the replacement.
Re: Activ8
« Reply #5 on: August 15, 2013, 18:43:37 »
I would never use an oil additive. Modern oils work very well. Nothing else is needed. What would they do that would be worth the money? Most add solids like graphite and PTFE that can clog oil passages and do not adhere to engine parts.
Offline hookie
Re: Activ8
« Reply #6 on: August 15, 2013, 21:23:24 »
I agree. Most vehicle manufacturers these days specifically recommend not to use additives at all. Just give the bike an oil (& filter if scheduled) change before you go. Use a quality oil as specified and take a little extra with you if the bike is likely to use any during the trip.
Offline Locky
Re: Activ8
« Reply #7 on: August 15, 2013, 22:03:30 »
Waste of money imo . A good branded oil is all it needs .
Re: Activ8
« Reply #8 on: August 15, 2013, 23:25:31 »
+1 to what's been said already. Rather spend the extra cash on a good double ester based fully synthetic motorcycle oil.
Re: Activ8
« Reply #9 on: August 16, 2013, 07:49:58 »
OK, I think that is enough about oil, between here, the deauville owner forum and the idiots on the GZ125, who think fully synth oil will cause clutch slip on a 10hp single, I don't think I could take another oil thread!  :angry-banghead:
Re: Activ8
« Reply #10 on: August 16, 2013, 12:02:28 »
Fair enough, I'll keep it out of the engine then!
Thank you for your feedback.
Re: Activ8
« Reply #11 on: August 16, 2013, 12:04:20 »
Quote from: "mr_diver"
In the Oil/Lubrication section of the oily rag part of the forum?!
Re: Activ8
« Reply #12 on: August 16, 2013, 13:16:54 »
He posted in the wrong thread, should have been in the Moaning Old Git thread :neen:
Re: Activ8
« Reply #13 on: August 16, 2013, 19:12:09 »
:old:
Offline Chris Graves
  • Bike: V-Strom DL 650, ZZR 1100, Honda CRF250L
Re: Activ8
« Reply #14 on: August 17, 2013, 22:11:54 »
Quote from: "Juvecu"
I think I'd rather spend the extra on some double distilled cognac and leave the oil without any additives.
Seriously I hammer my bike engines, change the oil and filters at requisite intervals and so far no problems.  Cue the ZZR throwing a rod through the side of the block tomorrow morning.
Offline disco man
Re: Activ8
« Reply #15 on: September 27, 2013, 15:34:04 »
Quote from: "Chris D'Pirate"
have used active8 in a couple of my bikes including my new vstrom got to say its great never experienced any problem with clutch slip and I'm getting a few more miles to the gallon when you first use it put the whole bottle in. then every 5 oil changes or 25.000 miles then you only need half a bottle from then on. I repeat never heard anything about clutch slip I think people get frightend about this. would recommend activ8
