Author Topic: Over tightened sump nut - options?  (Read 4248 times)
Offline stevee_p
« on: July 05, 2013, 15:43:49 »
So, like a idiot, I've over tightened the sump plug. I was trying to undo it, and was actually tightening it, serious idiot territory. I've done the oil change, put the plug back in, and it does tighten, although when it gets to the stage where it feels like its really tightening up, it then goes loose. Basically I've buggered the thread. As it stands now, the plug is in, as tight as it will go. No oil seems to be leaking, and it is pretty tight. But I'm just aware it's not as it should be.
What options do I have? Are there any thread repair solutions?
Quick replies appreciated (probably unlikely given its Friday afternoon and the weather is GLORIOUS!)
Cheers.
2002 K2 DL1000
Leo Vince, Givi, Corbin, Power Commander
http://www.pbase.com/stevee_p
Re: Over tightened sump nut - options?
« Reply #1 on: July 05, 2013, 16:01:21 »
There will come a time when it needs to be removed. At that time, you can determine whether a thread chaser will fix things. If not, a helicoil, timesert or tapping for a larger drain plug will be necessary. It's not a nut.
Offline stevee_p
« Reply #2 on: July 05, 2013, 16:06:35 »
But can it be ridden as it stands? It's not leaking on tick over, but I've no way of knowing if riding it would work the plug loose.
2002 K2 DL1000
« Reply #3 on: July 05, 2013, 17:13:54 »
It's not going to be a gusher in any case. It will almost certainly be fine but check the ground for oil before each ride.
Offline Jacko
« Reply #4 on: July 05, 2013, 17:46:06 »
There's no way I'd ride it like that, get it sorted..
