Author Topic: Torque wrench for oil change  (Read 4333 times)
Offline stevee_p
« on: June 25, 2013, 11:49:47 »
Do you use one? Or simply do it 'tight enough'
2002 K2 DL1000
Leo Vince, Givi, Corbin, Power Commander
http://www.pbase.com/stevee_p
Offline frez
Re: Torque wrench for oil change
« Reply #1 on: June 25, 2013, 12:31:21 »
I have done it by hand in the past on other bikes, but it is really not worth the risk that you will strip some threads by over tightening it. I use a torque wrench on critical fasteners like this all the time now.
Offline Strommer
« Reply #2 on: June 25, 2013, 12:34:15 »
Hand, just tight enough to feel a new washer compress.
A disgrace to biking...
Offline Jacko
« Reply #3 on: June 25, 2013, 12:49:59 »
I use one if I know the value, if I don't I go by feel, if in doubt go gentle, if oil leaks out nip it up a bit, if not then your work is done.
« Reply #4 on: June 25, 2013, 13:33:12 »
Just keep your head in the game. I once forgot to set the torque on the tool and stopped before doing damage when it didn't click when it should have. Set the clicker type to zero before putting it away or the spring can take a set.
Offline cubeconn
  • Bike: DL650 K4, GSX1100SD Katana (x2), GSX400SSN Katana & TZR250 2MA
« Reply #5 on: June 25, 2013, 14:51:32 »
Always by hand for 25 years until I finally got a torque wrench about 3 years ago (for another task) and now I have it, I feel I need to get my money worth from it :-)
I never stripped a thread or got a leak in all that time, but am happy to have it correct now!
DL650K4 bought in April 2005 with 1800 miles, now showing 45000 (July 2018).
Offline TravellingStrom
« Reply #6 on: June 25, 2013, 23:10:28 »
I do it tight with a normal spanner, Suzuki kit, it does not give mych leverage. I don't change the crush washer, never had a leak nor stripped it yet
TravellingStrom
