Author Topic: Anyone tried Halfords Chain Wax 400ml?  (Read 5682 times)
Offline Descolada
« on: April 19, 2013, 14:06:42 »
I was wondering if any of you fine folks had tried the Halfords Chain Wax 400ml - What are your thoughts on this stuff?
Des
Offline Tommy3Tanks
Re: ANyone tried Halfords Chain Wax 400ml?
« Reply #1 on: April 19, 2013, 17:35:53 »
Tried it and still have the can, nearly full. made the chain look like it was covered in candle wax. Until it got dirt in it then just looked nasty. Using muck off chain lube at the minute and its clear and does the trick. I like a shiny looking chain, just wish I had the drive to make it that way  :)
Offline Fatbelly
« Reply #2 on: April 19, 2013, 19:44:16 »
I quite like wax in the winter when the roads are salty - it stops the side plates of the chain from turning brown.
Offline Descolada
« Reply #3 on: April 19, 2013, 23:11:25 »
Quote from: "Fatbelly"
I have this problem almost constantly, clean the chain, lube it and then a few days later it is turning brown again. I hate that, cause it's not good for the chain and makes it look like you don't care.
When it's due for change I am considering getting one of the DID heavy duty gold chains. We'll see if that helps keep the brown stuff away.
Re: Anyone tried Halfords Chain Wax 400ml?
« Reply #4 on: April 20, 2013, 12:06:03 »
It does :thumb:
Offline adst
« Reply #5 on: April 20, 2013, 18:33:57 »
Cleaned my chain today ..ran out of my fav. Wurth lube ...non greasy or waxy ...went to heine gericke and  they sold me a spring bucket of chain cleaner , bike cleaner , chain lube ..white? , sponge and 10 quid off if you spend 30 before sept token ...good value , but not sure I like the white chain lube ..looks waxy which means grit sticks? ..will see
Because life is the journey not the destination?
"Dr.Pat Garrod ..Bearback "
Offline hump333
« Reply #6 on: May 04, 2013, 22:57:37 »
This is the best of the best in quality and service for chains it doesn't fly everywhere. Ebay the best an cheapest prices8-)
