Following on from Brockett's domestic appliance rant.
My youngest Step Daughter's oven control switch detached itself from the inside of the built in oven control panel. We popped over to Lincoln yesterday after watching a YouTube video it seemed fairly straightforward, remove oven, remove top panel, find switch dangling by it's wires, refit switch AND bend over locking tab to stop it happening again. Jobs a good 'one.
We drove over there in my old Volvo, as it was parked directly in the sun I decided to tilt the sunroof open. When we set off home I went to close the roof, nothing happened. Still the sun was shining and the air con was doing an excellent job....
Further into the journey (Dunham Bridge) I had a call from my domestic appliance parts supplier informing me that my new door gasket was ready for collection. Yep our washer at home had sprung a leak.
When I arrived home I was rather pre-occupied with sunroof's, I did the usual checked fuses, checked google that suggested locking and unlocking the car several times, holding window switches etc, naturally none of these worked. I then found a post on a forum about closing the roof manually, this involved drilling out rivets in the motor and winding the gears. This worked.
Flush with the partial success of a mended oven and a closed roof I decided the seemingly simple gasket change should be next. I'd watched a a three minute video which seemed reasonable, I even disconnected the power.
Removal was a piece of piss, pull out the outer retaining ring, the inner one was a little more of a challenge but after making a tool to release the spring securing ring that came out too. To remove the gasket simply peel as if you were removing a tyre and there you have it.
It took me two hours to fit the new fecker. I removed the balance weight for more room, I watched and re-watched the video numerous times before it made any sense and even then I think it was just a fluke that I managed to fit the new one.
All back together and no leaks.
