Author Topic: Keis ?  (Read 2087 times)
Offline Locky
Keis ?
« on: December 17, 2011, 16:08:23 »
Thinking of getting the heated waistcoat , any of you got one ? what's it like ?
Offline Oop North John
Re: Keis ?
« Reply #1 on: December 17, 2011, 16:27:45 »
I've had one for a couple of years with no problems. Personally I prefer it when using the batteries you can buy for it, as then you don't have to connect / disconnect the lead from the socket every time you get on / off. And it means you can be toasty warm when off the bike.
Offline Locky
Re: Keis ?
« Reply #2 on: December 17, 2011, 16:40:18 »
How long do you get out of the batteries ?
Re: Keis ?
« Reply #3 on: December 17, 2011, 16:55:41 »
Quote from: "Locksmith"
Depends on the heating setting but I'd reckon on about 4 -5 hours on level 2 setting. 1 being lowest 5 is max. Not a cheap option, but less faff.
Offline PCBlock
Re: Keis ?
« Reply #4 on: December 18, 2011, 19:40:05 »
I've also used a Keis waistcoat for 21/2 years now. The waistcoat  is very effective and for the price (its still about the same as I paid and often discounted), I'd say go for it. The problem with Keis heated gear, (I also had a pair of the in-soles), in my experience is the wiring is not very durable. I've just had to repair the cable to the waistcoat controller again after it split. Keis also use a smaller size of coax plugs to other heated clothing manufacturers which can be a problem if you want to link it up to say a Gerbings controller.
Offline StreetHippo
  • Bike: DL650A K9
Re: Keis ?
« Reply #5 on: December 19, 2011, 19:27:54 »
Love mine!!!
Also bought the battery pack as it means I can use it when watching the boy play football!!!
It is good for at least 2 hours on level 4, longer on lower levels. Invaluable!
Stu
