Clothing
Winterizing your gear
Topic: Winterizing your gear (Read 2558 times)
Upright
September 13, 2011, 14:01:38 »
Thompsons water Seal
Posted this on the US forum and here
Its the only tip I have and I think its the roseta stone for commuting.
I buy 5 litres about 20urals should be cheaper in the UK
I put it in a squirty bottle and spray it on all my gear - textiles, leather even the parasol in the garden. It seems to coat the material and the water beads on it. Because I doesn't soak in the gear doesn't get saturated and so is dry in the morning.
Also it seem to stop the Sh!t sticking (to the outside that is - I'm fairly advance when it comes to bowel control)
Much cheaper than the aersol containers and much less chance of breathing in the product during application
I have no Idea what's in it and am not about to educate myself as I won't stop using it and in that case ignorance is bliss
I will admit to puting leather water proffing on A set of Spada extreams instead of the thompsons but that's cause they are so thick I felt it might make them more pliable - hand sore and all that
As I say I like it, but I buy cheap, heavy gear and give it the once over every few months.
If your a Klim or rukka wearer maybe you should - as they say - test on an inconspicous area first.
It's not my fault, it's your fault. I told you I was stupid but you didn't listen!
Fatbelly
Re: Winterizing your gear
September 13, 2011, 15:36:37 »
Just a quick question. This sounds great but exactly which Thompson Water Seal product are you using? Is it the one they use on wood & brickwork etc?
I can see that on their US web site they do an aerosol can of water seal for leather & fabric but I can't see this on any UK sites or in 5 litre containers.
maybe they are the same stuff?
Fatbelly
September 13, 2011, 15:42:17 »
Forgive me for answering my own question but I found a fishing website where they have been using it on clothing, tents etc., it is the same one they use for wood, bricks, & concrete!
They say it pongs a bit until you air it.
Upright
September 13, 2011, 15:46:17 »
I pong a bit anyway
Its fine coz you don't put it on and then wear it straight away. its something I dod after waswhing the gear and drying it every two months or so. Means I don't really have to buy top of the range for waterproofing anyways and Lidl/Aldi always have warm ger with liners etc.
Never had a problem yet
Ptarmigan
Bike: CRF1000 Africa Twin
September 13, 2011, 20:08:34 »
+1 for Thompsons...
I used to soak my old army surplus camo gear in the stuff then hang it in the garage to dry out. It didn't make them totally waterproof but took a heavy downpour to get through, more often than not it was the seams that were 'stretched' anyway!
Locky
Bike: Triumph Tiger 800xc & Yamaha TTR250
Reply #5 on:
September 13, 2011, 20:26:46 »
My mate tried it on his fishing brolly last year , done mine now and seems to work a treat . Stopped it leaking and it just shakes dry .
Clothing
