Author Topic: blue flame  (Read 924 times)
Offline pikeman
blue flame
« on: June 03, 2010, 17:49:20 »
well got the new pipes on, would put pics up but never fathomed out how to do it on here !!!!. Quick question I think they have not sealed somewhere as first 5 miles great smoother running at 3000 rpm, then later it felt like fuelling was off, stuttering on constant throttle and bogging down unless I was fairly aggressive with the throttle. Any ideas ? the pipes are great look good and sound good  :grin:
If it is a poor seal how do I rectify this?
Lokk forward to your insights.
Offline Fenris
Re: blue flame
« Reply #1 on: June 05, 2010, 11:59:07 »
Have you removed the baffles in the exhaust? I suspect they're making your engine run even leaner so I'd see how it works with the baffles in and if that's still no good I think you'd want to remap the fuel injection with a Power Commander or similar.
GPX750 > GS500 > Hornet 600 > DL1000
Offline wobblybrother
Re: blue flame
« Reply #2 on: June 06, 2010, 14:50:29 »
Hello Matt ,Have you tried taking out bottom port baffle plate's this should help. Regards, Mark
I smile a lot cos I ain't got clue what's going on !!!
