Bash Plate Noise Reduction
Topic: Bash Plate Noise Reduction (Read 1475 times)
Mark65
Bike: Vstrom DL650 AM2
Location: Wigan (sadly the great pie shops are gone, RIP Pooles pies)
July 27, 2025, 17:13:46 »
Hi All,
Did a run to Blackpool and back today and although I'm getting used to the extra noise from the bash plate I noticed above 70 I get a resonance, below about 66 its gone, I'm assuming its the bash plate, has anyone used the bitumen noise pads that stick to the plate to reduce the sound?.
Thanks
Mark
NeilM
Bike: DL650A L4, R1200GS, Triumph TR7 / T140, Bluroc X-Bongo 125
Re: Bash Plate Noise Reduction
July 28, 2025, 06:55:45 »
I'm not sure which bash plate you are using, but I had exactly the same issue with a Cosmo bash plate.
It took a while to track down, but in the end I put a strip of bicycle inner tube between the plate and the rear mounting bracket, so that it's squashed between the two and that stopped the noise.
Gert
July 28, 2025, 09:45:09 »
Reply #19 of
https://www.stromtrooper.com/threads/givi-skidplate.441490/?post_id=5677573#post-5677573
, recommends Noico 80 mil 10 sqft car Sound deadening mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening from amazon.
A link for those who wish to enquire,
https://www.amazon.com/Noico-deadening-Automotive-Insulation-dampening/dp/B01KZ5X7KO?crid=3K6WY8AO39WOC&keywords=noico+auto+sound+deadening+material&qid=1683561234&sprefix=noico+auto+sound+deadening+material,aps,135&sr=8-3
Replies #8 and #17 of the linked discussion has a couple of pix if anyone is interested.
Mark65
July 28, 2025, 10:46:56 »
Thanks, will try the innertube first.
Mark65
July 31, 2025, 06:53:35 »
Hi, I bought a packet of 2mm m6 penny washers, 20mm diameter and put them between the plate and mounts, so far it works great, ringy resonance gone and its has made things more less noisy, I'm happy with it.
