Author Topic: Wind noise  (Read 8327 times)
Offline Robert kostromin
  • Bike: DL650
Wind noise
« on: August 20, 2022, 09:42:51 »
Hi any ideas how to stop wind noise VSTROM 650 thanks
Re: Wind noise
« Reply #1 on: August 20, 2022, 10:06:31 »
Ear plugs.  :thumb:
Offline Rixington43
  • Bike: DL1000GT K7
Re: Wind noise
« Reply #2 on: August 20, 2022, 10:29:54 »
If not already wearing them then yes, specifically I like Docs Pro Plugs with the vent in. They're incredibly comfortable providing you buy the correct size and they block high frequencies whilst allowing mid range through. I wear them to play drums and ride the bike, highly recommend.
Failing that, screens with flip ups are nice as you can leave them down at low speed and flip up for cruising.
Re: Wind noise
« Reply #3 on: August 20, 2022, 11:25:26 »
Your crash helmet can also be a problem for wind noise.
As said, Earplugs are the way to go .  :thumb:
  • Bike: DL650
Re: Wind noise
« Reply #4 on: August 20, 2022, 12:27:26 »
Hi thanks
Offline Mep
  • Bike: DL1000GT K8
Re: Wind noise
« Reply #5 on: September 04, 2022, 12:21:18 »
Blimey,  how do you manage to play drums and ride the bike? :grin:
I use custom moulded plugs for playing bass and riding the bike. Not at the same time though.
Offline grumps
Re: Wind noise
« Reply #6 on: September 04, 2022, 12:32:17 »
Givi Airflow screen helps a lot.
Re: Wind noise
« Reply #7 on: September 04, 2022, 13:17:03 »
+1 for the Givi Airflow
Offline Upt North
  • Bike: DL650 L7
Re: Wind noise
« Reply #8 on: September 04, 2022, 13:26:33 »
Less Beans.
Offline KVstrom
  • Bike: DL1000XTGT L8
Re: Wind noise
« Reply #9 on: October 04, 2023, 18:58:51 »
I agree, always worn mainly Arai helmets but recently switched to a Shoei and much less wind noise from these in my opinion.
Offline timangus
  • Global Biker
  • Bike: CF Moto 450MT
Re: Wind noise
« Reply #10 on: October 08, 2023, 19:55:28 »
I tried 4 different screens on mine to get one that wasn’t as ugly as the Givi Airflow, but ended up buying one as nothing works as well. Now I can ride with my visor up.
Offline Sea-Strom
  • Bike: DL1050A (2022), Fat Bob (2023), Softail Standard (2023)
Re: Wind noise
« Reply #11 on: October 08, 2023, 21:17:11 »
Unscrew top, standard screen bolts half way. Remove bottom pair. Insert 2 or 3 thick rubber tap  washers between screen and lower holes. Screw in 4 bolts and screen is raked back several degrees. Problem of wind and noise is often solved this way dependent on rider height. I did this mod on my 3 V-Stroms...Mk 1,2 and 3. Cheap mod and can be very successful. Worth a try for the price of a couple of bits of rubber from a plumbing shop!
PS - I only had buffeting on the 650's - the 1050 rides pretty quiet at speed but rider height and helmet design plays a part too.
Offline Milo
  • Bike: DL650XT L0
Re: Wind noise
« Reply #12 on: December 05, 2023, 22:11:06 »
I went with an MRA Vario touring screen and smaller mirrors.  Got rid of noise and buffeting.
Offline pb
Re: Wind noise
« Reply #13 on: December 06, 2023, 07:32:04 »
Another vote for the Givi airflow , also gets rid of the turbulence.
