December 07, 2021, 19:11:22
Author Topic: Rear brake assembly problems  (Read 663 times)
Online kwackboy
Re: Rear brake assembly problems
« Reply #20 on: August 02, 2021, 22:43:55 »
If your spacer (item 10) hasn't been changed or modified and the aftermarket bolt is still fouling the disc , I'd say it's too long.
Online Rusty Nuts
  • Bike: KTM 1090
« Reply #21 on: August 03, 2021, 06:39:56 »
Yeah, apologies for the red herring regarding thread length. I was looking at the bolt in isolation, rather than how it behaves when assembled. Oops.
Offline Keith60
« Reply #22 on: August 03, 2021, 08:02:01 »
Take the bolt out, put a nut on it, grind 5mm off the end of the bolt then take the nut off to ensure the thread isn’t damaged.  Job done.  That’ll cure it, what ever parts have been change previously.
Never too old to ride!
Offline V-Twin
  • Bike: DL650A L4
« Reply #23 on: August 03, 2021, 10:30:47 »
Quote removed
blokes, I think he has something assembled wrongly.
The Bolt looks like its the right size & length, after all that bolt came out originally.(the replacement bolt is correct too)
If the Spacer tube hasn't been removed, then too that means he has something wrong somewhere.
If you do cut the Bolt down, in my opinion that is the wrong thing to do.
Kobe needs to remove everything he did originally & start again.
Kobe, if you video the work as you do it you could always upload to youtube so we can see it, or send it to me. PM first.
Offline sillyboy
  • Bike: DL650 L7
« Reply #24 on: August 03, 2021, 15:35:44 »
the only problem I had was getting that
the only problem I had was getting that ******* no4 clip to stay in place.
Online kwackboy
« Reply #25 on: August 03, 2021, 19:26:07 »
This might sound a bit odd to some but,  you actually can't fit the whole rear brake assembly wrong, the parts don't fit any other way, not even the wheel spacers.
With everything in its correct place it all fits together,  if one part isn't in the right place it won't fit...  :shrug:
The picture I posted earlier is silly boys rear caliper and to me , it looks like it's fitted correctly  :shrug:
If the silver bolt is too long, it will foul the disc.
Offline V-Twin
  • Bike: DL650A L4
« Reply #26 on: August 03, 2021, 19:54:10 »
Some more measurements for you to look at.
Online Rusty Nuts
  • Bike: KTM 1090
« Reply #27 on: August 03, 2021, 20:34:19 »
That last pic is key. Kobe, do you have the tube (part no. 10)? Could you, as Vtwin has asked - a couple of times - post a pic of it with the bolt? How much bolt sticks out with the bolt head butted up to the end of the tube?
Online kwackboy
« Reply #28 on: August 03, 2021, 20:40:59 »
Just realised I got the names mixed up .. it's Kobe's picture not sillyboys ...  :whistle:
Offline V-Twin
  • Bike: DL650A L4
« Reply #29 on: August 03, 2021, 20:55:01 »
Just to let you know, that the set bolts thread protrudes 14mm out of the slider tube.
The ally caliper bracket is 14mm. And so, that is why when your bolt is fully tightened it will only show itself by 1mm at the most.
Also that is why the tread is further up than you think it should be. This allows the thread to tighten up on itself.
Effectively trapping the slider tube, so the caliper can move on the tube as the pads wear.
Offline Kobe
  • Bike: DL650 K5 2005
« Reply #30 on: August 03, 2021, 23:13:26 »
Good evening,
 after checking the lenght of bolt in bike I found that it's longer about 3mm. After I checked invoice and it is bolt from Kawasaki. So I went back to the shop and asked if they have any other bolt, but they don't. So I will order an original bolt made by Suzuki and hopefully it will do the trick. I will keep you updated if I find anything elese. Have a good night everyone. :]
Online kwackboy
« Reply #31 on: August 04, 2021, 17:37:41 »
Glad you've discovered the problem  :thumb:
