Author Topic: 650 lowering kit  (Read 230 times)
Offline doboy
  • Bike: 1050 v strom
650 lowering kit
« on: June 10, 2021, 18:06:39 »
Can anyone help my mate out . He want to put a centre stand on his 2017 650 v strom ..but...has a 40mm lowering kit on it , he thinks if he changes the 40mm to 20mm lowering kit the centre stand will fit OK ...is this the case ???
Offline davef
  • Bike: 2010 V-Strom 650 AL0
Re: 650 lowering kit
« Reply #1 on: June 13, 2021, 17:51:23 »
The stand should fit OK, but any lowering kit will make it much harder to actually get the bike up on its centre stand. Mine has been lowered by 15-20mm at the back and similar dropping the front fork tubes. I could just get it up on the stand with my full weight on the centre stand, but now I'm down to about 10st 5lb, I cannt do it unless I run the front wheel onto a piece of wood. Which is easy enough in the garage but not convenient otherwise.
Offline doboy
« Reply #2 on: June 14, 2021, 09:04:04 »
Cheers DaveF , I will pass it on to him  :thumb:
