Author Topic: Vstrom 1000 purchase  (Read 1440 times)
Offline nathanharold
  • Bike: None at present
« on: March 03, 2021, 11:56:32 »
Hello all
New forum member here.
I am considering buying this bike:
https://www.ebay.co.uk/itm/Suzuki-DL-1000-V-STROM-2014-EXCELLENT-COND-ONLY-1-OWNER-4-915-MILES-EXTARS/203179875375?hash=item2f4e76dc2f:g:BqMAAOSwK8NfrqZb
I've had a look through the forum and as ever there will be various issues. Is there a definitive list of things to check on a  2014 1000?
Thanks
Nathan
Offline nackeredspanner
  • Bike: DL1000 L4, 2003 Yamaha FZS600, Triumph Trident T300, 1979 Honda CX500, 200? Grey import Honda VFR400 NC21, Kawasaki GPZ750 1987
Re: Vstrom 1000 purchase
« Reply #1 on: March 03, 2021, 18:18:44 »
Hello Your Nathan, its not a bad looking bike with just under 5000 on the clock just make sure its had the ECU recall done if it needs it that is
« Reply #2 on: March 03, 2021, 20:03:04 »
See if the clutch basket has been fixed too.
  • Bike: DL650A L2 White
« Reply #3 on: March 03, 2021, 21:28:19 »
Wasn't there an earthing recall on them too?
Offline clutchspring
  • Bike: DL1000XT M0
« Reply #4 on: March 04, 2021, 07:37:01 »
That looks a nice clean bike, the first revamped version like this one did have some electrical issues, I believe the electrical block connecters under the tank wear not water proof & did causes strange electrical problems, also as some one  as already said they had a recall on a earth lead & some suffered from ignition switch & wiring harness rubbing under rear of fuel tank.
Worth ringing a Suzuki main dealer up with the bike reg number & they should be able to tell you if any recalls have been done.
Don't let it put you off there a great bike & no matter what make you buy they all have some sort of problems.
Good look,
Ian.
« Reply #5 on: March 04, 2021, 09:24:56 »
Looks like a good clean bike. Yes there was a recall for a new ecu and a recall for the none waterproof electrical connectors under the tank plus earth lead. The connectors and earth you can do yourself, I did mine( but that's if the connector is not corroded) and it's easy enought to see if the bike has the new ecu. On start up it'll rev to 2000rpm for 10 seconds if it has the new ecu, if not it'll just go to 1500rpm and drop to tickover almost immediately. I'd not worry about the clutch basket at that mileage, mine didn't start acting up to 20k miles and I rode it in to 33k before I got it fixed.
Take a test ride if poss as they're quite different to ride than a normal three or four cylinder bike. I love mine, my blade riding brother took mine a run the other week, thought it was a right Tractor!
« Reply #6 on: March 04, 2021, 17:11:05 »
Thanks for the info - I have agreed to buy the bike albeit remotely due to covid. Delivery week commencing 22nd March!
I did check with my local Suzuki dealer they ran the plate and the bike has no outstanding recalls. Only had 1 owner from new.
Fingers crossed it all checks out when it arrives - buying remotely has its risks but also covered by Visa and distance selling regulations so not as risky as it seems, albeit id rather view and test ride it but not possible at the moment due to covid plus the bike is 160 miles away.
I've had big vtwins before (Honda VTR firestorm) and my last bike was a Harley Davidson MT350e military enduro so the Strom will be very refined compared to the Harley! Had a Tiger 800 for a while but don't like super smooth engines they are boring I like something with character which sounds mechanical!
« Reply #7 on: March 04, 2021, 17:53:26 »
Welcome to the fold. They are a very underrated bike. I had a tiger8 before this, sure the tiger was lighter and smoother but I much prefer the vstrom, it has much more go in it and brakes that actually stop you!
The clutch will be noisy at tickover, there all like that don't worry. Once you get the screen sorted, the oe is terrible, you'll be good to go.
Hope you enjoy.
Offline jasonsean484
  • Bike: DL1000 L6
« Reply #8 on: August 09, 2021, 23:06:06 »
Hello , so any chance of a update ? how did it work out
