Author Topic: Starter woes.  (Read 515 times)
Offline Ken Morrison
  • Bike: DL650A K8
Starter woes.
« on: July 23, 2020, 19:18:40 »
Hello Folks
  My name is Ken, I recently purchased a 2008 DL650a. I have been away from bikes for some time but I am certainly enjoying riding again. Has anyone had problems with the starter ? Sometimes it takes 3 or 4 attempts to get the starter to engage, I suspect there is a bad spot on the commutator.
Thank you.
Online Asmith61
  • Bike: DL1000 K7, B-King 2011, 1200 Bandit 1999 Triumph trophy 1200 1999
Re: Starter woes.
« Reply #1 on: July 23, 2020, 19:39:34 »
Hello ken  :welcome:
Offline bosnjo
  • Bike: DL1000 L7
Re: Starter woes.
« Reply #2 on: July 23, 2020, 20:29:32 »
Can be voltage problem. First check if battery connections are tight. If yes, then measure voltage before trying to start the bike. It may be just as simple as low voltage and you need to charge the battery. VStrom needs a lot of riding to fully charge the battery. I had similar problem with my 2018 DL1000 and it was because of low voltage.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
Online kwackboy
Re: Starter woes.
« Reply #3 on: July 23, 2020, 20:31:06 »
 :welcome:
Offline Joe Rocket
Re: Starter woes.
« Reply #4 on: July 23, 2020, 20:40:14 »
Hello from France.
I'd go for the starter motor brushes on a 12 y. o. bike. Often one rubs down more than the other. I don't suppose they're cheap, Yamaha ones aren't.
Enjoy the bike and have lots of fun!  :grin:
I need some fine wine and you, you need to be nicer
Offline joethebike
Re: Starter woes.
« Reply #5 on: July 23, 2020, 23:11:14 »
  • Bike: DL650A K8
Re: Starter woes.
« Reply #6 on: July 24, 2020, 00:54:37 »
Thank you for the suggestions, I have replaced the battery with a new one and installed a battery tender. The previous owner gave me an excellent service manual so I'll use it to troubleshoot the problem as soon as the weather clears up. We've had thunder storms all day and I don't have a garage.
Re: Starter woes.
« Reply #7 on: July 24, 2020, 07:17:34 »
Do you have a waterproof cover for your bike when it stands out over night? Besides a battery not hold it's charge (which you have now ruled out), there are two reported causes for inter or non starting. These are the clutch switch connector not making correct contact and the starter button on the right hand cluster. Have you read https://blacklabadventures.com/2012/02/19/start-switch-maintenance/ ? If these check out OK, then as suggested, check the starter motor brushes by shorting out the starter relay tags. This step by passes all safety switches. Just make sure that you bike is not in gear when you do this or you will end up dumping your ride should the starter motor turn. You may want to read https://www.stromtrooper.com/threads/the-case-of-the-reluctant-starter.165857/
Online roganjoshing
  • Loving my first Vee Twin
  • Bike: DL650 L0
Re: Starter woes.
« Reply #8 on: July 24, 2020, 13:39:13 »
I've just replaced a dodgy switch unity that did the same on a 2010 650
Offline sillyboy
  • Bike: DL650 L7
Re: Starter woes.
« Reply #9 on: July 24, 2020, 18:41:19 »
hailstones the size of a looney in alberta according to a correspondent on a farming forum.
  • Bike: KTM 1090
Re: Starter woes.
« Reply #10 on: July 24, 2020, 18:43:11 »
 :shrug: Why the quote?  :shrug:
Re: Starter woes.
« Reply #11 on: July 24, 2020, 19:12:50 »
The last sentence....."hailstones the size of a looney in alberta according to a correspondent on a farming forum" was added by sillyboy Rusty.
The same happened the other day, the 'new post' was written inside the quotation marks of the quote.   :)
Retired Breakfast Tester.
Offline sillyboy
  • Bike: DL650 L7
Re: Starter woes.
« Reply #12 on: July 25, 2020, 15:12:05 »
sorry blokes, don't know what I did wrong with the quote/post.
Offline sillyboy
  • Bike: DL650 L7
Re: Starter woes.
« Reply #13 on: July 25, 2020, 15:14:56 »
and I wrote blokes not blokes. maybe the gods thought I wrote gays and I was being homophobic? :)
Offline sillyboy
  • Bike: DL650 L7
Re: Starter woes.
« Reply #14 on: July 25, 2020, 15:16:19 »
the computer she say no blokes .
Offline sillyboy
  • Bike: DL650 L7
Re: Starter woes.
« Reply #15 on: July 25, 2020, 15:17:43 »
bloody hell, hope you get your starter fixed. :grin:
Offline TLPower
Re: Starter woes.
« Reply #16 on: July 25, 2020, 15:25:45 »
No G.u.y.s
  • Bike: DL650A K8
Re: Starter woes.
« Reply #17 on: August 01, 2020, 21:28:15 »
Update, I replaced the brushes in the starter this am with a set I ordered from amazon.  DB Electrical SMU9120 Starter kit. $38.00 Can . The old brushes were worn down to the point that the springs had bottomed out. Works good now ! Thanks everyone.
Offline Joe Rocket
Re: Starter woes.
« Reply #18 on: August 01, 2020, 21:58:17 »
Looks like at least two Joes got it right.  :sunny:
Glad you're sorted.  :thumb:
Offline oslin
  • Bike: DL650A L5
Re: Starter woes.
« Reply #19 on: August 02, 2020, 12:25:17 »
Just a thought, when you say three or four times to get the starter to engage, do you mean the starter is dead for a while or is it running but not doing anything ? because if that is the case it sounds like the sprag clutch (starter clutch) is at fault.
