Author Topic: 2019 V-strom 650 vibration 6k  (Read 262 times)
Offline Pablo
  • Bike: DL650 L9
« on: July 09, 2020, 20:30:19 »
Hello, does anyone else have a buzzy vibration @ 6-6500 ?
it only seems to started since fitting some givi crash bars and an metal sump guard, everything is tighten and after 6 weeks of buzz vibrations nothing has fallen off, anyone had a similar issue ?
Online Fat Rat
  • Bike: DL650A L6
Re: 2019 V-strom 650 vibration 6k
« Reply #1 on: July 09, 2020, 20:52:43 »
try loosening all of the Crash Bar fixings, tighten the join where the bars meet in front of the Rad and then tighten the rest.
** Biker Friendly Campsite in West Wales **
I will NEVER use JT's Motorcycles of Swansea! http://www.v-strom.co.uk/smf/index.php?topic=2717.msg205443#msg2054
Offline Pablo
  • Bike: DL650 L9
« Reply #2 on: July 09, 2020, 22:19:44 »
Thanks I will give that a try and report back
« Reply #3 on: July 10, 2020, 07:38:35 »
http://www.DL650.org/photos/pbsoluces/Ricky/vibrations-crash-bars-givi.html has pix showing a possible solution for the Givi crash bar vibration on the earlier model Glee (#6 in parts list). Maybe this solution may be of help on your model. Any rubber washer of the correct diameter should do the same function. I made use of 2x bath tap jumpers, to fit over the bolt as shown in the last pix of the attached link. The bath jumper centers had to be widened a bit to all the bolt to fit.
Other solutions have been recommended, like the garden hose snap lock extender to replace the connector in 2nd last pix of the post link. The snap lock coupler has a rubber water seal O ring on each end of the plastic coupler, that goes inside the carsh bar tube, effectively replacing the original (item #3 of parts list). Example of this snap lock extender can be viewed on https://www.amazon.co.uk/Double-Connectors-Extender-Garden-Green/dp/B072K468RP
