Author Topic: Another DIY disaster  (Read 921 times)
Re: Another DIY disaster
« Reply #40 on: May 21, 2020, 18:50:59 »
I get the feeling that will need drilling out. With a threaded sleeve on the plate it doesn't give much room for tapping it out. A good pillar drill with a bolted down vice is what you need. Failing that, grind off the threaded insert and have a nut welded to the plate instead.
 "One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors." - Plato. Not Jason, the other one.
Offline Stonec0ld
  • I was Paul_Nicholson
  • Bike: DL650A L5
« Reply #41 on: May 21, 2020, 19:42:27 »
Thanks all, TLP you have a PM awaiting
  • Bike: 'onda Varadero XL1000v9, 'onda CX500ec '83, Yam XJ600n '96, GSX14 '06, DL650 K6 (Blue) R.I.P,
« Reply #42 on: May 22, 2020, 00:03:42 »
A new replacement bracket is £51 which is a bit steep for a bit of pressed steel but not the end of the world.
I would have given up after 10-15 mins of attempting to extract the remaining section.
Got the grinder out and welded on a new nut.
Even my shitty welding skills are capable of a couple of tack welds with an arc welder.
(The mrs only recently told me she learnt to weld in year 9 D&T.
They didn't let us near anything like that in my school- the teachers knew us too well.  lol
That may be why she's got a degree and a career and I'm the thick one running a shop and setting peoples garden furniture on fire  :shrug: )
  • Bike: SV650: Z900RS: VZ800 : VX800:
« Reply #43 on: May 22, 2020, 00:52:17 »
 lol
Look at the clock and the calendar.
It'll never be now again.
So just get out and do it.
As fast as you possibly can.
Because .........
Nothing travels faster than the speed of time.
Offline TLPower
« Reply #44 on: May 22, 2020, 12:28:24 »
Sorted. I simply welded on a flange nut and it came straight out.
Offline Stonec0ld
  • Bike: DL650A L5
« Reply #45 on: May 22, 2020, 12:37:24 »
Fantastic! Not having either a flange nut or welding equipment that would have taken me ages...
You're a true gent TLP!
Offline user650
  • Bike: DL650 L7 in fast white (Gen 3), 2017 Suzuki Address 110 also in fast white
« Reply #46 on: May 22, 2020, 12:54:21 »
He does have his moments  :whistle:
If It Starts Ride It
Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
« Reply #47 on: May 22, 2020, 15:15:50 »
 :clap:  :bow-blue:
Because .........
Online UK_Vstrom650
  • Bike: DL650A L2 White
« Reply #48 on: May 22, 2020, 15:25:26 »
Nice one  :thumb:
What was the problem then? Rust? Dodgy bolt?
Offline TLPower
« Reply #49 on: May 22, 2020, 16:02:19 »
No corrosion at all, not even a speck of rust anywhere. I suspect the bolt had been seriously over tightened at some point, either pulling the female threads too close together or galling them.
Offline kissofdeath
  • Bike: Veek
« Reply #50 on: May 22, 2020, 16:07:42 »
well done mr power, I'll keep u in mind next time I make a balls of something  :whistle:
Offline Keith60
  • Bike: DL650 AL7, Honda NT700, Honda TRX 500FA ATV
« Reply #51 on: May 22, 2020, 19:51:15 »
TLPOWER!!!  What a star!  :bow-blue: :bow-blue: :bow-blue:
Never too old to ride!
Online Asmith61
  • Bike: DL1000 K7, B-King 2011, 1200 Bandit 1999
« Reply #52 on: May 22, 2020, 21:01:25 »
TLP well done mate  :clap: :clap:
Online kwackboy
  • Bike: 2015 BMW F800GS Adventure. An old Honda CB500s
« Reply #53 on: May 22, 2020, 21:20:26 »
Nice work TL ..  :thumb:
Online Rusty Nuts
  • Bike: KTM 1090
« Reply #54 on: May 22, 2020, 21:37:25 »
That's enough, now. Don't encourage him. Back on community service tomorrow.
Offline TLPower
« Reply #55 on: May 23, 2020, 06:00:10 »
True dat. :roll:
