Market Place
Wanted
2010 DL 650AL0 LHS Indicator (clear type)
Topic: 2010 DL 650AL0 LHS Indicator (clear type) (Read 780 times)
Aidan123g
Bike: DL650A L0
May 08, 2020, 09:43:20 »
As per title really, have damaged the left hand side indicator and looking to replace with a original one if someone has one spare. This is the clear indicator as opposed to the orange.
Regards Aidan.
Vera
Bike: DL1000A L8
Re: 2010 DL 650AL0 LHS Indicator (clear type)
June 24, 2020, 18:56:20 »
Hi, I have a set from a 2018 DL1000 if you want to see if the part number is the same and are any good to you?
Zero miles as had LEDs fitted at dealer before bike collected !
Ianmc
Bike: DL650AL5
June 24, 2020, 22:09:05 »
Don’t forget that the indicator lens are handed.LH front is the same as
RH rear and Vice versa.I have a set of K9 clear lens,but they are different to the ones in this picture.Not sure if they are the same as yours.
Market Place
Wanted
