Author Topic: Thank You to this Forum  (Read 858 times)
Offline gg02355
  • Bike: DL650 L2 White
« on: September 06, 2019, 18:21:02 »
I just wanted to give a well deserved THANK YOU to all who contribute on this forum......
I've had two problems with my Glee over the last month and both were solved quickly, cheaply and pretty simply!!
Issue No 1
Very occasionally the bike would not start, not even an attempt from the starter motor. Then 1 minute later it would start faultlessly. After a quick search on here, figured it was likely to be the clutch switch, ordered a new one, swapped it out and abracadabra problem sorted  :bow-blue:
Issue No 2
Last night after meeting up with a few mates, went out to the bike, started her up and no headlight or main beam, absolutely nothing. Everything else was fine. Checked the fuses and all seemed OK. Decided to make the short trip home just using the side lights  :crazy: Had a quick search on the forum this morning and a previous suggestion was it was likely the starter switch had got stuck. Just finished taking it apart, giving it a good clean and some TLC and abracadabra problem sorted  :bow-blue: :bow-blue:
Online UK_Vstrom650
  • Bike: DL650A L2 White
Re: Thank You to this Forum
« Reply #1 on: September 06, 2019, 18:24:04 »
 :text-goodpost:
« Reply #2 on: September 06, 2019, 18:28:01 »
 :text-goodpost: :icon_wink:
« Reply #3 on: September 06, 2019, 18:32:36 »
 :thumb:
  • Bike: VX800: KTM 390 Duke,
« Reply #4 on: September 06, 2019, 19:03:01 »
That is what a proper forum is all about.  :thumb:
Offline Ridaz
  • Site Donator
« Reply #5 on: September 07, 2019, 10:19:20 »
 :thumb:  :text-goodpost:
Offline Graham62
  • Bike: DL650 K6 Blue
« Reply #6 on: September 07, 2019, 13:01:51 »
 :bow-blue: :bow-blue: :thumb: :text-goodpost:
Graham
Offline Asmith61
  • Bike: DL1000 K7, B-King 2011, 1200 Bandit 1999 Triumph trophy 1200 1999
« Reply #7 on: September 07, 2019, 16:04:26 »
