Author Topic: hard luggage  (Read 1757 times)
Offline farmerandy78
  • Bike: DL650 L4
hard luggage
« on: March 15, 2019, 08:44:39 »
hello - I would be grateful for any advice.  I have 2014 650 V strom love it 1st bike only had it for 2 years.  It came with givi small hard panniers and I would like to upgrade to hard larger cases.  There is so much to choose from new and secondhand can anyone point me in the right direction ?! any tips be gratefully received.
Thank you.
Offline Mark Shelley
  • Bike: GW250 SV650N
Re: hard luggage
« Reply #1 on: March 15, 2019, 16:25:50 »
In my opinion you simply cannot beat the old school top loading ally boxes. They are so much easier to use than lids that hinge down. If you remove the two mushrooms and ‘toblerone’ shaped locking piece you will be left with bare frames to fit them to.
If you pick up a second hand pair you will have to adjust the locations of the pucks that are usually used to fit them, but that is simple enough.
Offline timangus
  • Global Biker
Re: hard luggage
« Reply #2 on: March 16, 2019, 02:18:10 »
I have both but still prefer the plastic side loading cases for lightness. Alloy cases and frames are heavy before you start adding luggage but for my RTW trip top loading alloy cases were chosen for their strength in case of a fall and the ability to strap things on top of them like a tent. As you have frames already the cheapest option is to change the cases for any of the E range like the E45/E36 or standard Trekker. The Outback versions required heavier frames. The V range use different shaped frames altogether. There should be plenty on fleebay to chose from to save money and getting coded locks to match a top case is easy.
Offline Banditbilbo
  • Bike: DL1000 L8
Re: hard luggage
« Reply #3 on: March 16, 2019, 09:06:46 »
As the previous post, I also prefer side loading panniers.
I have Shad SH36  with 3P support.
Maybe better because:
They are more light than alus.
You have more loading flexibility with side loading than top side loading.
They are cheaper than the others.
Also I had H&B  semirigid panniers on my old Bandit 650, with C bow fitting system.
They was waterproof (also 12 years later), lights and C bow its nice, because seems like there is no pannier frame in the machine.
Good luck
Re: hard luggage
« Reply #4 on: March 16, 2019, 10:44:58 »
If you want to save dosh and keep your current pannier frames, you have to identify exactly which panniers you have on. As they are Givi they will be either 'e' or 'v' type. see HERE for examples (there are older 'e' type panniers knocking around, too). Then once you have id'd them, you know what pannier frame you have, and can choose a bigger set of panniers. Try Ebay, and shops like this one https://www.sportsbikeshop.co.uk/
Offline Willie Fawcett
  • Bike: DL650XT L5, 2014 Suzuki GSX-S750, Honda MSX125SF
Re: hard luggage
« Reply #5 on: March 16, 2019, 18:12:23 »
I have some Suzuki  genuine luggage which you are welcome to look at. I in godalming Surrey . May be for sale in near future . Same as in pics .
  • Bike: DL650 L4
Re: hard luggage
« Reply #6 on: March 17, 2019, 14:38:26 »
this is all very helpful thank you - I have the V35 givi side panniers - that makes sense re the weight of the metal ones.
Maybe I will keep the side panniers as they are and then get a bigger top box thanks for your help
Online Rusty Nuts
Re: hard luggage
« Reply #7 on: March 17, 2019, 17:54:06 »
And as you've probably sussed by now, the v35 cases and their frames are specific to each other. If you want bigger panniers you'll have to switch frames.
Offline user650
Re: hard luggage
« Reply #8 on: March 17, 2019, 22:51:10 »
K33 fitted to the rear (same as v35), E22 to the front, simples
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
  • Bike: DL650 L4
Re: hard luggage
« Reply #9 on: March 18, 2019, 11:39:07 »
wow that photo ! thanks
Re: hard luggage
« Reply #10 on: March 18, 2019, 12:11:02 »
Yeah, I think you over did it with the tank bag, User650...
Offline user650
Re: hard luggage
« Reply #11 on: March 18, 2019, 14:16:05 »
Its not a tank bag its a cake bag  :thumb:
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
