Author Topic: New Bridgestone Battlax Adventure A41 tyre  (Read 31137 times)
Offline Frostilicus
Re: New Bridgestone Battlax Adventure A41 tyre
« Reply #20 on: November 05, 2018, 16:59:18 »
Great news Moby - I posted in January that my A40s were looking like they needed replacement, but here we are, 10 months later and they still look like the did in January, even though I've done 14k miles on them in total!
This has settled it for me - when my everlasting tyres do actually decide to give up the ghost, I'll replace them with A41s :)
Offline Nelson
  • Bike: DL650XT L7
« Reply #21 on: November 07, 2018, 11:18:29 »
My A40's did 10,500 front and the rear did over 11,000 with plenty of tread left but squared off so naturally changed as a pair. A41's have now done 2500 miles and perform as well - can't say I detect any better performance but still very happy. Tyre fitter failed to clean off the hardened ridges left from green slime puncture preventative, so tyre slowly lost pressure, sorted now.
You'll never find yourself flying down the road wishing you were wearing less protective clothing.
Offline Frostilicus
« Reply #22 on: November 30, 2018, 11:26:01 »
My A40s have finally been changed, a puncture on the front was the final incentive to change them - the shop have fitted a pair of A41s for me, I would have been happy with A40s to be honest, but I guess they can't get those any more.
Will report back in a few miles to see how they go, I'm hoping for more of the same really as I find these to be excellent tyres
Offline paulja
  • Bike: DL1000XT L8
« Reply #23 on: January 02, 2019, 19:26:36 »
How are those A41 going? I'm close to new tyres and those is on the list to consider.
Offline mobytrip
  • Bike: DL650X K7
« Reply #24 on: January 03, 2019, 11:06:57 »
Had a good look at mine this morning as MoT due next week.
Still happy with level of grip, doesn't seem to matter if it's hot, cold, wet or dry they just grip.
Got 7k on them now and the rear is starting to square off, but I do a lot of motorway miles commuting to work.
I will replace with the same when it is time and in the past on other bikes I have never been a fan of Bridgestones but these have changed my mind.
Offline Frostilicus
« Reply #25 on: January 07, 2019, 09:23:32 »
I've now done just over 1k miles on the A41s and am very happy with them indeed.
They seem to perform just as well as the A40s I had on before, no trouble in heavy rain and good road holding at motorway speeds too.
Scrubbing in took me around 70 miles or so, the usual weird feeling up to that point but very well behaved now!
Offline Rhino VStrom
« Reply #26 on: January 15, 2019, 00:03:54 »
Offline Dave L
  • The older I get the faster I was......
  • Bike: DL650 AM3
« Reply #27 on: March 05, 2019, 19:51:07 »
Hi,
Thanks for the article.
I have managed a mammoth 14k miles so far on my A40's and am due to take trip to Spain and France in June so will be investing in a new set of A41's.
Offline Woodyflyer
  • Bike: L5 Glee, Bandit 1200, Burgman 650. 1050 RR
« Reply #28 on: June 01, 2019, 09:22:57 »
Just fitted a set of A41 to my Glee, noticed that the Suzuki handbook states 33/36 front/back while bridgestone web site recommend 36/42
Any recommendations on which ones to go for ? , Did notice when they were fitting them the carcass is really stiff compared to my RP4s
What are you running yours at ?
Offline Old Biker
  • Bike: DL650A L3
« Reply #29 on: June 01, 2019, 13:32:54 »
Tyre specialist who fitted my A41's said the higher pressures were correct for the new tyres, I went with his view and the bike handles fine  :old:
Offline hotbulb
  • Bike: DL650 L4
« Reply #30 on: June 01, 2019, 17:10:32 »
I'm well into the second set of A41s, and when the time comes I'll probably go for them again ... I'm very happy with them. (Had the A40s previously - also liked them, better than the Anakee 3s I had on the Transalp, but I found the A40s rode a bit harshly).
I've used the Suzuki standard pressure (33/36), but I'll give the Bridgestone 36/42 a try next time I check the pressures  :fix:
Offline Woodyflyer
« Reply #31 on: June 01, 2019, 17:53:21 »
Just done first 100 miles to scuff them in using the standard pressures, all fine apart from the first half mile feeling a bit different, going to try the higher pressures​ to see if the handling any different.
Offline mobytrip
  • Bike: DL650X K7
« Reply #32 on: June 12, 2019, 08:43:32 »
Just changed on to my second set of A41 tyres. ultimately never been a fan of Bridgestone tyres but these are really good wet or dry, hot or cold. Commute all year round and have got just over 10k miles out of the old set, the front tyre down to the wear markers and the rear although still technically legal was very squared off so swapped out as a set.
Also had them set at the higher pressures by the tyre bloke, feels okay but as had them swapped out in the middle of a downpour yesterday and still wet today its hard to tell what they feel like, but plenty of grip, (confidence),  in the wet straight away
« Reply #33 on: June 12, 2019, 10:43:05 »
I too was not a fan of Bridgestone until I tried the BT-023 on SWMBO's GSX14.
Took a punt at some cheap A40's and they were far better than the old Battlewings that the Varadero came with years ago.
As a pure road tyre goes, they are great in the dry, confidence assuring in the wet and life span is better than most.
The 40 and 41 are the same compounds, but slightly different tread pattern to differentiate the two and the 41 comes in a wider range of sizes.
Offline Nelson
  • Bike: DL650XT L7
« Reply #34 on: June 26, 2019, 10:15:20 »
Changed front A41 slightly prematurely (she who must be obeyed says I'm always premature - not sure what she means) at just under 10,000 miles. £120 fitted, which I was happy with?
Usually change as a pair but couldn't bring myself to change rear as it's still great and only slightly squared off. Looks like it could get to 15k.
Admittedly I haven't tried other makes on my two Stroms in the past but are there better tyres out there? These seem unbelievably good to me - great feel wet or dry, excellnt life and prices seem OK?
Offline Dave L
  • Bike: DL650 AM3
« Reply #35 on: June 29, 2019, 16:41:19 »
Hi,
I eventually changed tyres at 16K miles, front was nearly down to minimum, predictably back had squared off but still had a few miles. Fitted new A41's and just returned from a week in Spain and am very happy with the performance.
Offline timangus
  • Global Biker
  • Bike: CF Moto 450MT
« Reply #36 on: June 30, 2019, 14:54:26 »
My rear A41 has done 7500 miles across Asia and looks in good order. Not as grippy as the Michelin but then its a 90/10 road tyre and the Michelin is a 80/20 and they did slip on unmade indian roads.
Offline Jamieboy
  • Bike: DL650XT L5
« Reply #37 on: August 11, 2019, 19:17:46 »
Just an observation on these tyres. I recently bought a glee with a41s on it. They've done about 5k miles with the previous owner. I set them to Bridgestone recommended pressures but felt the ride a bit harsh. I am fairly light though about 75kg. Put the pressures down to 34/38 ish and noticed this helped smooth things out so I'll keep them there, even if Bridgestone think they should be marginally higher. Seem decent overall but not done much mileage yet.
Offline paulja
  • Bike: DL1000XT L8
« Reply #38 on: January 31, 2020, 12:53:04 »
If the R5 are too pricey for you, these A41 are an excellent alternative, they don't disappoint once scrubbed in.
Offline snagzie
  • Bike: DL1000 L7
« Reply #39 on: March 04, 2020, 15:41:56 »
What pressures do you lot use with A41's on a Veek 1000? I've just got the default 36F/42R at the moment but as it's a completely new bike to me I wouldn't know if it's worth dropping them a bit.
I've done 90 miles on the rear and 40 on the front so far so not proper scrubbed yet (the bike came with a new rear, so fitted a new front 50 miles in)
