Author Topic: F1 error C49 = PAIR control solenoid valve Now what?  (Read 4160 times)
  • Bike: 2025 Triumph 660 Trident in gloss black, 2022 850 V7 Stone in Matte Black, 2025 Royal Enfield Guerrilla in Brava Blue
« on: February 03, 2017, 19:19:04 »
The bike has not been used for a longish time.
The engine started but with F1 light on.
Put into dealer check mode and C49 was indicated on the dash.
"PAIR control solenoid valve".
Anyone have a hint or three as to what I am to look for / check?
Battery shows 12.45 volts across the terminals with ignition switched off.
Re: F1 error C49 = PAIR control solenoid valve Now what?
« Reply #1 on: February 03, 2017, 19:27:58 »
I just found it in the on line manual so I know where to start. Possible maybe I dislodged something when I changed the air filter.
Oh! damn I have take all that stuff off again to check it out.
Offline Hondaman
  • Bike: 650 L3
« Reply #2 on: February 03, 2017, 20:17:19 »
I can't see there being any kind of sensor to check/confirm operation so probably the connector has not been fitted properly
Offline TLPower
« Reply #3 on: February 04, 2017, 05:22:01 »
Typical bloody train driver, always blaming the signals....... lol lol lol lol lol lol
« Reply #4 on: February 08, 2017, 18:38:47 »
Managed to get some garage time today  :fix: and so I stripped off the bodywork,tank and lifted the air cleaner to find I had not connected the sensor  :icon_no:
All back together and starts and runs fine.  Only a road test to go before it is declared fit and well after all the work I have done on it.
