Author Topic: Aux fusebox  (Read 179391 times)
Re: Aux fusebox
« Reply #500 on: May 20, 2017, 18:36:15 »
A cable rated at 11A (based on 13.8V DC) would cope with 150 Watts. What are you looking to run from it?
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #501 on: May 20, 2017, 18:52:04 »
I use massively overrated cable on the fuseboxes. My heated gear doesn't even pull 11amps all together. You should be able to use that cable for most accessories
Offline Freddyfruitbat
  • Bike: BMW R1200RS
Re: Aux fusebox
« Reply #502 on: May 20, 2017, 20:45:23 »
Thanks BP, much appreciated - I thought I'd checked my rating correctly but this stuff just looks so... flimsy. Anyway, I'll crack on.
I located the orange rear light cable on my Glee that I needed to tap into, but even having raised the fuel tank the plug was right down deep below the coolant bottle, really tight with no slack at all, and I could barely even get my finger tips down there.  Is that normal?!  Almost certain it's OEM Suzuki.   I eventually managed to get the connection made, but it was really tricky and took me ages and much cussing!
Can I give you one bit of constructive feedback on the design?  For the Glee, at least, it would be good to have another inch of cable between the inline fuse, to make routing that cable easier if you want the fusebox in the space by the coolant bottle, as it's a bit limiting (see another punter's photo at http://www.v-strom.co.uk/smf/index.php?topic=24607.msg317497#msg317497).
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #503 on: June 04, 2017, 10:52:28 »
I've got some now. With a longer wire between the ring terminal and inline fuse as suggested by Freddyfruitbat. PM me for one.
Offline crabbitoldgit
  • Bike: 2014 V-Strom 1000
Re: Aux fusebox
« Reply #504 on: June 13, 2017, 16:53:07 »
Fitted my aux fusebox today. Worth every penny and highly recommend getting one. Only issue was the switched live feed connector on my bike was buried deep in the guts of the engine bay. Once I'd moved the coolant expansion bottle out of the way it was just about reachable. Would have been easier with girlie hands, not the two shovels I was born with ;-)
Offline kissofdeath
  • Bike: Veek
Re: Aux fusebox
« Reply #505 on: June 30, 2017, 07:52:21 »
1st class support as per usual !!!!!!!!!!!!! :obscene-drinkingchug:
Offline jasonsean484
  • Bike: DL1000 L6
Re: Aux fusebox
« Reply #506 on: July 01, 2017, 01:38:48 »
hi bigpie , have you any left mate , would like one , cheers
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #507 on: July 01, 2017, 08:42:01 »
I've got 2 left. You have PM.
Offline northern_southerner
  • Bike: DL650 L0
Re: Aux fusebox
« Reply #508 on: July 01, 2017, 22:36:55 »
I will take one also if available
many thanks
Offline hotbulb
  • Bike: DL650 L4
Re: Aux fusebox
« Reply #509 on: July 14, 2017, 11:06:49 »
And I'd like one too, if still available, please.
(Have just discovered that the heated grips are connected via a wire just pushed into the fusebox alongside the fuse  :shock:)
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #510 on: July 14, 2017, 11:19:49 »
I'm all out at the moment. I'll post when I've made more up.
Offline hotbulb
  • Bike: DL650 L4
Re: Aux fusebox
« Reply #511 on: July 14, 2017, 11:29:11 »
Thanks,  BP  :thumb:
Offline thehobo
  • Bike: VSTROM 1000 2018
Re: Aux fusebox
« Reply #512 on: July 29, 2017, 22:51:04 »
I would like one too :-) fantastic looking kit! cheers
Offline gg02355
  • Bike: Versys 1000
Re: Aux fusebox
« Reply #513 on: July 30, 2017, 09:20:25 »
Bigpie, could I add myself to the list for a fusebox  :)
Offline Beags
  • Bike: DL650 2015 XT
Re: Aux fusebox
« Reply #514 on: September 09, 2017, 23:25:20 »
Would be interested in aux fuse box, have you any at the moment,
Cheers John.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #515 on: September 10, 2017, 07:22:13 »
I've none at the moment, but it looks like there's interest. I probably be making more up in a few weeks, I just haven't got the time right now, with work and kids.
Offline Tris
  • Bike: V-Strom 1000 K8
Re: Aux fusebox
« Reply #516 on: September 10, 2017, 23:29:51 »
I would be interested in one too
Offline richardjeaton
  • Bike: Suzuki Intruder VL125
Re: Aux fusebox
« Reply #517 on: September 18, 2017, 21:12:36 »
A friend has had one of these from you and I'd like one too when available please?
Offline bluepoolshark
  • Bike: DL650GT K8
Re: Aux fusebox
« Reply #518 on: October 04, 2017, 22:49:55 »
I would like one when you make your next batch please
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #519 on: October 05, 2017, 08:21:29 »
The parts are in a box on my desk. I should be starting them tomorrow.
