Author Topic: Satnav bracket for new Glee  (Read 29208 times)
Offline S2Rgar
  • Bike: DL1000 L9 Black - DL650 AL5 Red (SOLD) - DL650 AL3 Grey (SOLD) Suzuki GSX-S1000
Re: Satnav bracket for new Glee
« Reply #20 on: January 19, 2014, 18:21:33 »
I have my doubts it'll fit. Had a look just now but it's too dark to see properly. I'll post up a photo of my Madstad bracket tomorrow and you can tell me if you recon it'll work. Hope it does.... looks a nice bit of kit.
Gary
« Reply #21 on: January 19, 2014, 21:58:48 »
I worked with Madstad to make sure the bracket would work with the SW Motech bracket with each using different mounting holes. The SW-Motech angles the bracket to fit while the Cymarc uses a flat design and standoffs to clear the center fairing bump which won't work if the Madstad has to use different holes than the Cymarc. As long as the Madstad uses the same holes as the Cymarc though, it shouldn't be a problem. The Madstad bracket will fit on top of the Cymarc bracket like it does on the SW-Motech bracket in this picture.
Offline S2Rgar
« Reply #22 on: January 20, 2014, 12:32:15 »
That all makes perfect sense greywolf, thanks.
As I have my Madstad bracket set on the lowest position I'd need to change it to the highest position to use the cymarc bracket unless there is still plenty room for the ram ball if I keep it on the lowest one.
It's starting to get a bit hit or miss now...  :shrug:
« Reply #23 on: January 20, 2014, 14:23:54 »
Why is it hit or miss?
Offline S2Rgar
« Reply #24 on: January 20, 2014, 15:07:13 »
Because I might only be able to use the cymarc bracket on the highest setting, a setting I didn't like my screen at. I know everything is adjustable with the Madstad so I'll move my set up from it's current low position to the high one and see if I like it. Hopefully it'll be OK as I'd like to give the fella my business again.
« Reply #25 on: January 20, 2014, 21:28:47 »
If the RAM ball impinges on the fairing in the lower hole set, it can probably be mounted in the front of the satnav bracket. If the Madstad bracket still doesn't clear, it can be mounted on spacers to move it out a bit.
Offline Big Wooky
« Reply #26 on: January 29, 2014, 13:00:15 »
Stupid Question time..... :fix:
Where could I get the longer M5 Allen Bolts and longer spacers, I think I may need?  and what length?
I have a Givi Airflow screen fitted.
Also, seeing as I'm at it any way.......how easy is the Sat Nav cable routed from here to the 12v socket fitted on the right handside of my bike?
Thanks in advance.
Rules are for the obedience of fools and the guidance of wise men.
Offline Stobie
« Reply #27 on: January 29, 2014, 13:55:59 »
I got these:
http://www.ebay.co.uk/itm/10-Pack-M8-mm ... 4d1324b044
Pick your size - standard on the MRA touring screen are M5 15mm x 15 long and 15mm x 10 long.
For the M5 bolts I used these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0126705059
Stobie
Offline Big Wooky
« Reply #28 on: January 29, 2014, 14:39:54 »
Quote from: "Stobie"
I got these
Excellent....... thanks Stobie.
Offline Lipstick
« Reply #29 on: January 31, 2014, 10:17:26 »
Exaxtly what I been looking for. Great build for a great price. I want one! The question is, will you post to Sweden?
Offline cymarcbikeparts
  • Site Donator
« Reply #30 on: February 01, 2014, 13:17:53 »
Quote from: "Lipstick"
yes pal - it ain`t cheap but if you are willing to pay then please contact my highly desirable Shelly at shelly@cymarc.co.uk and she will quote you Donkey off  :ty:
« Reply #31 on: February 01, 2014, 13:20:58 »
Quote you donkey off? Is that some kind of northern sex game?
  • Site Donator
« Reply #32 on: February 01, 2014, 18:19:01 »
Well you might have thought that but its the forum filters I think.
It won`t let me print a-s-s as one word, putting in `donkey` (my wife's - and yours - pet name for me btw)
 :limp:
Offline EireSkull
« Reply #33 on: February 11, 2014, 12:19:16 »
Quote from: "Fat Rat"
The Ram Ball/Arm combination gives the flexibility to mount any GPS at any angle, far less complicated  :thumb:
Is that a 2inch or 3inch ram socket in the in the picture?
I'm waiting on one from cosmos and wondering which one to order.
Offline zimcruza
  • Bike: 2016 Veek
« Reply #34 on: February 11, 2014, 14:32:27 »
Any ideas if this fits comfortably behind / in front of (whatever you prefer, delete as necessary) a Givi AirFlow screen??
Offline S2Rgar
« Reply #35 on: February 17, 2014, 14:59:41 »
Quote from: "cymarcbikeparts"
If it doesn`t send it back (or give it to fatrat) and I`ll 100% refund you  :liar:
(but seriously, I would)
OK... just ordered one. Hope it fits  :shrug:
Offline stibbs
« Reply #36 on: February 17, 2014, 21:30:21 »
Fitted mine the other day. Excellent piece of kit well worth the money. Very helpful service as well, recommended :thumb:  :ty:
Offline S2Rgar
« Reply #37 on: February 17, 2014, 22:45:16 »
Aye, I got good service from him when I bought stuff in the past.
Just hope it fits with my Madstad and I'll be well pleased. :dance:
Offline adst
« Reply #38 on: April 13, 2014, 18:37:56 »
Great piece of kit ..fitted in 10 mins.. Used longer spacers under ram mount and screen to lift Suzuki vario screen ..seems great
Ram mount slightly vibey but great to have it high up above clocks , great to deal with Marc sent me longer m5 screws ...before the screen even arrived ! What a star !
 :lala:
Because life is the journey not the destination?
"Dr.Pat Garrod ..Bearback "
Offline my orange vstrom
« Reply #39 on: April 19, 2014, 16:16:26 »
love the Sat Nav mount...
I need one for my 2011 model ( annaloge clocks )
do you do one ?
Tom.
