Took me a good 30 minutes, but managed to get the exhaust off. Like my old man (a diesel mechanic) says: "It doesn't have a mother or a father so it doesn't have a will!" Meaning it will bend to my will
It did bend a little, right where I hit it numerous times, but I think it will need replacement anyway. The joint on the collector pipe has a quarter rusted away. At least the header pipes seem usable.
The Strom is now almost completely stripped, just need to take the brake discs off, knock some bearings out, get the tyres removed and strip the forks. I'm going to be doing all that tomorrow along with a big cleaning session and then it's off to the powdercoater.
I uploaded 84 pictures today, here's a few:
Shortly after I started, in a good mood, enjoying myself and 'keeping hydrated', as you should in this kind of heat
Exhaust off
Used the provided threaded holes, stuck a bolt in it with some chain and rope to lower the engine with:
Engine dropped (not literally!)
Not too bad looking for 100k+?
Looks a bit naked now...
Brakes, wiring and cables stripped off:
Rear master cylinder cheese bolts, rounded off immediately and then the filings that came out stuck to the allen socket tip. Shitty stainless is that magnetic.
Had to grind the heads off after cutting grooves and hitting them just didn't yield any results. This was a massive waste of time that could've been avoided by Suzuki using normal bolts instead of shitty stainless button head ones that were screwed into aluminium. Those just fuse together over time, chemical reaction or something like that. I'm going to need another heel plate, this one's damaged.
Those bolts are so shitty I could break bits off them with a vice grip. I have no idea if I will be able to get them out of there without damaging the master cylinder. That's a problem for another day.
This one was my fault, I used an A2 stainless bolt that screws into the aluminium swingarm and it looks like I forgot to coat it with something so that the two don't react. Yay for road salt aggravating the problem...
Sub frame off:
Forks off:
Rear wheel out:
Swingarm off:
Done for the day:
