Author Topic: Mind of its own !  (Read 1070 times)
Offline Locky
Mind of its own !
« on: October 07, 2012, 12:34:55 »
It first happened on ST5 , went to start the bike the clock needles went round , pulled in clutch , pressed starter and nothing ! Ignition off and try again and it fires up . Happened yesterday so pulled the clutch in/out a few times and it started , so I'm guessing at a faulty clutch lever switch . Can these be cleaned or should I just renew ?
Offline loggamatt
Mind of its own !
« Reply #1 on: October 07, 2012, 12:40:59 »
Could just be lazy? I feel like that when my alarm goes off in the morning sometimes :)
Offline LaKraven
Re: Mind of its own !
« Reply #2 on: October 07, 2012, 12:50:41 »
Quote from: "Locksmith"
Can't hurt to start out trying to clean it with lots of WD40. Worst-case scenario: replace it!
Black DL650AK9 GT, 09 reg: 1" lower front and rear, USB charging and lighter sockets, Madstad bracket, Slipscreen and large Givi screens (for purpose), Aux Light Bar, fog lights (switched), custom ignition-switched wiring loom
Offline hookie
« Reply #3 on: October 07, 2012, 13:46:53 »
If you have an alarm/immobiliser fitted this might also be the problem. They can be a real headache and I personally would never fit one. Had to take the one of my Vee as this was causing  problems.
Offline Locky
« Reply #4 on: October 07, 2012, 14:42:04 »
No alarm etc fitted , more trouble than what they are worth ..
Offline Strommer
« Reply #5 on: October 07, 2012, 14:46:43 »
Does it fire if you are quick, but not fire if you delay between switch on and the start button?
A disgrace to biking...
Offline Locky
« Reply #6 on: October 07, 2012, 17:32:00 »
Not sure Strommer , I'll try it if it happens again . I've removed the clutch switch and washed it out with contact cleaner , I'll see how it goes now .
Offline Abercol
  • Bike: 2016 Explorer XRT
« Reply #7 on: October 11, 2012, 17:31:03 »
Mine was doing that recently too, I checked all of the switches, but it was the starter switch, a prolonged squirt of wd40 cleaned it out and alls now good, starting first prod again.
