that's looking good Neil. Will get myself down to Screwfix and get a can. I need to change my clutch cable anyway - spotted it was just starting to fray last year and got a new one but never fitted it, so two birds with one stone and all that.
I also spent a good bit of today in the garage sorting out the rear brake caliper. The piston wasn't too bad, but the pads were filthy and almost looked corroded. I was going to swap them for a new pair as they're looking fairly worn anyway but having measured the rear disc, it's now at 4.3mm so a new one is needed. I've therefore cleaned the pads and popped them back in while I order a new one.
I also rechecked the front left caliper as I thought the sliders on the mount wasn't moving freely, only to discover it was fairly stuck. A good blob of red rubber grease on the pins and they're sliding freely again.
Finally, I've readjusted the chain and decided it's definitely time to replace the Roadsmart 3s.
