December 07, 2021, 18:30:31
Author Topic: What have you done with your V-Strom today?  (Read 803449 times)
« on: February 27, 2012, 11:05:56 »
Fitted some Nissin brake calipers from a CBR600 using SV Racing brackets on Saturday (so no technically today...) Also put some new EBC HH pads in them. Doesn't make as much difference as I expected, but I put most of that down to my terrible brake hoses. Even with the bad brake hoses I have better feel from the brakes now. A good squeeze is worth more than it was before so I have high hopes when I get the hoses replaced too. With that in mind I also measured up the current brake hoses to get better ones made up this week. Somewhere along the lines I measured something wrong because the numbers doesn't look right, I will have to redo it. I'm going use a 2 hose from the master cylinder, one to each caliper, setup.
Thanks for the trade for the calipers Hutchie :thumb:
Offline Strommer
« Reply #1 on: February 27, 2012, 13:11:00 »
Do you mind keeping a hold of the measurements etc?  I'll copy you at my next service (or earlier) as my hoses need doing.
Oh... and I have done an oil and filter change.  Put some Castrol Power 1 Racing Fully synth in.  It's red!
A disgrace to biking...
Offline cearnshaw
« Reply #2 on: February 27, 2012, 13:16:50 »
filled the scottoiler, tucked the lead for the leccy gloves under the seat as it's warming up
Honda xr125, Bandit 650, v-strom 650 ABS 2001 W650 Versys 1000
Offline Coval
« Reply #3 on: February 27, 2012, 13:36:44 »
I have been a boy on Saturday:
wash and dry
wipe rust from the sides of the chain
lubricate all hardware affected by the road salt
replace longer "dog bones" with the original ones, lubricate suspension bearings
adjust the chain and align it correctly
drop the drop the front (raise the forks) by 15mm
remove muffs - expecting a heatwave
adjusted suspension preload front and rear
Piaggio X9 250 > Kawa GPZ900R > Yam GTS1000 > Yam TDM900 > Yam FJR1300 > K7 Wee & '98 VFR800Fi
Offline Spike
« Reply #4 on: February 27, 2012, 13:37:08 »
I looked at it and thought, those German flies from September wil hopefully get washed off the next time it rains, also checked the oil level
Offline Strommer
« Reply #5 on: February 27, 2012, 14:12:32 »
Quote from: "Coval"
...remove muffs - expecting a heatwave...
Well, that's the good weather cursed then..... :angry-tappingfoot:
Offline willbo
  • crazy is contagious
  • Bike: 2010 dl650x
« Reply #6 on: February 27, 2012, 14:25:00 »
Checked all fluid levels
Checked tyre pressure, tread and condition
looked at the chain, nicely lubed by the oiler
Looked at the mounted 3cs, tried to work out the powerlet wiring route
Offline Abercol
  • Bike: 2016 Explorer XRT
« Reply #7 on: February 27, 2012, 14:48:11 »
Nowt, its still alseep in the hut under its tarp....Did think about going to the post office to take it off SORN on Saturday morning, then the Mrs suggested I come back to bed...and, well, its still on sorn  :thumb:
« Reply #8 on: February 27, 2012, 15:11:07 »
Yep Strommer, will keep the measurements on record. I'll PM them to you once I have made sure they are correct (if I remember...) It's difficult to get an accurate measurement. I took some rope and put it along the hose, moving along at small intervals, and then measured the rope afterwards (used nylon rope that doesn't stretch much.) I think I wrote one measurement down completely wrong.
Offline 2112
  • Bike: Triumph Tiger 1200 Alpine Edition
« Reply #9 on: February 27, 2012, 15:48:02 »
I've just fitted my spanking new Wilbers shock, looks a thing of engineering beauty. Thankfully not much of a drama to change either, which is nice.
Offline Strommer
« Reply #10 on: February 27, 2012, 15:52:17 »
Quote from: "Juvecu"
Yep Strommer, will keep the measurements on record...
Ta.  NB Also put Puncturesafe in my new tyres.
« Reply #11 on: February 27, 2012, 16:18:02 »
2112, had a ride yet with the new shock? First thoughts?
Offline Piglumps
  • Bike: None at this point
« Reply #12 on: February 27, 2012, 16:29:14 »
Today? Looked at her through the window and thought - 'Mmmm up to 17C tomorrow - ride to work?' ...
No bike at present.......
Offline 2112
« Reply #13 on: February 27, 2012, 17:54:49 »
Sadly just bounced on it in the garage, with a bit of luck I'll be out at the weekend. This could be a nice answer for a shock replacement as it's between the Hagon and just about everything else price wise.
  • Bike: 1990 VX800: 2021 KTM 390 Duke: 2021 Honda NC750XA
« Reply #14 on: February 27, 2012, 18:37:39 »
Topped up scottoiler, cleaned oily goo off rear wheel. Wired up a relay to power Satnav, fitted and wired up satnav mount.
Used a telescopic magnet to fish odd nut from inside fairing/ bodywork.
Spent ages freeing off siezed centre stand.
Spent more time wondering where nut in fairing came from.  Can't find nutless bolt anywhere.
Thinking about MOT tomorrow  Hmmmmm ..  other posts remind me to check tyre pressures.
I haven't got a bike MOT'd since the seventies as I have always traded in within three years so if anyone knows of common fail problems I'd be obliged for some tips.
Dave
Offline Kaboo
« Reply #15 on: February 27, 2012, 18:54:48 »
Does it still count if the garage did something to the Strom today ?  :fix:
Duques Garage fitted my Garmin Zumo 220 -  :lala: - powers off when you turn the ignition key off - using the powers of the dark art of electricity in there somewhere  :icon-mrgreen:
 :lala:
« Reply #16 on: February 27, 2012, 19:18:04 »
Shees! Some people have really been busy.
For the MOT, check brake pads properly and make sure the fluid level is high enough.
« Reply #17 on: February 27, 2012, 19:57:54 »
Juvecu - brake pads, oh! yes, I will check and hope they're OK and I haven't left it too late.
thanks
Is it just me that feels waiting for an MOT result is like a new dad outside the labour ward !!!
Dave
PS wee was MOT'd OK. Only an advisory that the rear pads were wearing unevenly indicating the caliper is not sliding as it should and may need lubrication.
I have ordered new pads and some lube.
Offline metbandit1
« Reply #18 on: February 28, 2012, 16:56:31 »
Strom has been washed and I've attended to the rust problem on the chain after this winter!
The track bike has also been attended to though, rear wheel off and front to be taken off tomorrow with a bit of help. (seems to be stuck so getting someone more mechanically minded to help).
« Reply #19 on: February 28, 2012, 17:02:51 »
Brakes have bedded in nicely now and the last air is out of the system after it getting some use. Much improved compared to standard. Will probably measure that hose tonight and see if I can get the brake hoses on order soon.
