It's an easy job - take out the screw beneath the removable mounting plate, lift out the spring then find a washer that fits over the centre shaft & pop the screw back on. Much more substantial mounting and you just loosen the screw to adjust it if needed.
This looks a lot like the GoPro cameras when it's in that waterproof box. I've always thought the GoPro is too big and expensive, but that's just me
Only seems to be 360p as well...
