Author Topic: Suzuki luggage - original (?)  (Read 964 times)
Offline REM
« on: August 04, 2023, 09:45:46 »
Hello.What the company make Genuine Side Cases, Pannier Set New 93100-31820 ?? What I need to do make bigger ? I don’t want to change rack only make bigger panniers. Thanks.
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
Re: Suzuki luggage - original (?)
« Reply #1 on: August 04, 2023, 10:29:09 »
Hepco and Becker make Suzuki panniers unless something has changed recently?
« Reply #2 on: August 04, 2023, 12:33:56 »
Depends on the year of the bike, if it's a classic K2-L1 it would be branded as "SOFT" and they were awful.
SW Motech also made the metal boxes labelled up as Suzuki.
Online Rusty Nuts
« Reply #3 on: August 04, 2023, 13:07:44 »
Didn't Shad make a set as well?
Offline Upt North
  • Bike: DL650 L7
« Reply #4 on: August 04, 2023, 19:05:32 »
REM, post some pictures of the mounts, it might help.
Upt.
  • The Doctor 46
« Reply #5 on: August 04, 2023, 19:28:44 »
I posted the part numbers on google and it came up with these, are they the same as yours?
https://www.ebay.co.uk/itm/NEW-GENUINE-Suzuki-DL650-DL1000-VSTROM-SIDE-CASE-PANNIER-SET-93100-31820-000-/274557106331
I don't know who makes them but someone here will.
Offline REM
« Reply #6 on: August 05, 2023, 13:26:44 »
Yes its my luggage- but I look at something bigger
Put North- https://imgur.com/a/TQcJqSE
Offline Upt North
  • Bike: DL650 L7
« Reply #7 on: August 05, 2023, 17:26:10 »
I don't know but I suspect you will only be able to fit the original bags on there. You may have to go aftermarket carriers and panniers. The Shad 3P is a nice system. And not too expensive and will give you about 35L per side.
Good luck.
Upt.
Offline AdvntureSi
« Reply #8 on: October 09, 2023, 12:08:56 »
I haven't found anything bigger that fits the "Suzuki" set up..  I find it is heavy, overly complicated and has little space inside..
I am looking at what alternatives there are, I will poss go Givi if I can identify what panniers fit and don't interfere with the exhaust..
Anyone got pics of their alternative setup??
Offline bonne
  • Bike: DL1050 M0
« Reply #9 on: November 12, 2023, 10:27:44 »
My alternative Shad setup in the correct location; Spain. I now have the original panniers though - like mentioned in earlier post.
Alternative and original has their own pros and cons.
