Rode out to Bikers Worlds in Coleshill, met up with jstrom there. He got some Anakees 2 tyres fitted and then we swapped the lower, rear engine bolts. My short bolt for his long one as I had bought his old bash plate from him and needed the bolt to fit it. Rode home, took the front wheel off, went to the local ProTyre and had a new tyre fitted. Got back home, forks off, old oil out and new oil in. Uses a few millilitres short of a litre of oil if you use a 170mm air gap as I do. Forks back on, made them stick out the top by 10mm, been meaning to do that for ages and always put it off. Front wheel back on and new front brake hoses on too. Bled them, which was a bastard of a job, so I ended up using a huge syringe to suck the air out from the bleed nipple on each caliper and that worked really well. Handle is tied to the bar for the night to get rid if the last air. Brakes feels loads better, ran it up and down the short road I live in and managed to lock up the front. I was braking very hard, controlled, at low speed, but didn't expect to lock it up, must be the new front tyre and the paving stones here :eusa-whistle: The short is the brakes are now feeling very good after the recent upgrades: CBR600 calipers, EBC HH pads and new hoses. Also fitted the bash plate and the bike now looks more complete.
I picked up my Rental Raptor ATV handle bars at Bikers World, couldn't fit them because I couldn't find the original, shorter, handle bar clamp bolts so that I could remove the risers I have. Spent the better part of 30 minutes searching my whole garage and I couldn't find them anywhere. I'll have to get new ones, but I 'cleverly' didn't remember to measure the ones in there to know what to get.
BTW, I got 24151 miles out of the previous front Anakee 2, you can't ask for more than that from a tyre
In retrospect, if I changed it when I started feeling it was a bit worn and losing grip, then I would have changed it around 20K which is still very good for a front tyre. I now have a V rated one on instead of an H because that's all they could get. The H rated ones are on a 6 week lead time so if you are going to change, ask them to check for V stock if they can't get H.
