E-mailed Bridgestone at the weekend and, fair play, got an e-mail thismorning saying that they are looking into it and will get back to me. Not bad really.
Stu
JUST got this:
Right…. so by the sounds of your query, it would seem that the penetration you mention is more or less in the centre of the tread.
The conditions for general repair usually state that if the tyre is penetrated through to the casing stucture, then it would be quite difficult to repair. (these types of deep penetration can damage the internal steel structure of the tyre, and can let moisture in – even after the repair)
If a dealer were to attempt a repair, it would be at his own discretion.
At BSUK, we tend to to air on the side of caution, and would most definitely suggest a replacement tyre be fitted. (purely due to the sheer length of the offending object)
Hopefully this helps you. – Any questions, please contact us in the Technical Dept.
Thank you & kind regards
Paul
