I have just finished wiring a eco heating system.
Amazing bit of kit.
Ground Source Heat Pump, solar hot water, solid fuel stove heat recovery and air circulation heat recovery unit.
The fella must of spent a fortune on it.
Cat 5e cables from each stat to a Heatmiser UH1 and manifold, upstairs and down, plus one connected to heat pump heatmiser UH1 . All Heatmiser UH1's connected together by cat 5e cables. Six stat's upstairs seven down. In total 4 pumps, 5 zone valves, 9 cylinder stats, 1 solar over heat stat, 1 solar pump and a lot of head scratching.
Took 2 days to wire up. I have no idea if it works, plumber not finished.
I asked the fella how it all worked. He explained about the solar and ground source heat pump, then added if there is not enough temp in the solar and heat pump to run the system.
Wait for it. Now this is the genius part of the system.
You turn on the immersion heater
Its the 2nd eco system I have done. 1st one was a air recovery unit. worked like a fridge but in reverse,
It heated the hot water and underfloor heating. Guess what happens if the heat exchanger could not produce enough to heat the water.
Yep that's right it turned on a .... are you ready .
9 Kw immersion heater
So do they work or are they just a expensive gimmick?
